EXCESSIVE OIL CONSUPTION. PLEASE HELP
At around 30k miles it started burning oil and is currently burning 1 quart every 1500 miles. The dealer says its normal and not to worry but to me it seems extremely excessive. Can anyone give any advice on this topic.
What is causing the lose of oil?
What can it damage?
Can it be fixed or how is it fixed?
Ect.
Are you still under warranty?
Don't neglect it it will get worse.
Another option may be to simply change out your PCV and see if it helps any. Also, try pulling your plugs and see if there is any oil present.
Good luck.
The only way to get an exact reading is to track how many miles you've driven since the last change, drain the oil entirely, measure how much came out, and do the math.
For as long as I've owned an MB, I never relied on the engine computer to tell me to change the oil...I would still check it manually via dipstick if I had to check.
Great points but that oil consumption is not that bad at all. If you drive quickly it burns even more oil. Its normal. If you had a M156 it would eat even MORE oil.
I spoke to them and they said one main concern about burning that much oil is premature cat failure.
Ive never seen it blow smoke but the exhuast tips and rear diffuser just get coverd in what looks like soot from a chimney.
they may use a boroscope to check for excessive carbon build up but I think the compression and leakdown tests will be far more telling than a visual inspection.
