Smoke from exhaust
I have seen the smoke before also but it seems to have got worse. Thoughts?
Other things <might be> too much oil in crankcase...worn valve guides...worn/stuck rings...burnt piston...<most> times if the engine is "worn out" you won't see exhaust smoke after initial startup when engine is at operating temp, because of the temp of cats. Pull your oil fill cap off and look for an abnormal amount of engine blowby with the engine running.
If there are no unusual engine noises...cautiously, take your car out get up to operating temp for several miles and make a <somewhat> spirited run thru the gears
<legally of course
> Still problems, see your SA
g/l
Why does on get the smoke if one just drives the car in and out of hte garage? What is the 'smoke'? I have been doing detailing and spotting which did require going in and out of the garage a lot.
If I still get smoke, I am not sure I will know what normal levels of blowby are [not sure what blowby is even]. Perhaps then on to the dealer.
Thanks again.
<legally of course
g/l
If you're losing no oil whatsoever ... are you sure it's "Blue-ish" ??? And not simple condensation at start up?
Lots of blue smoke on start up is likely valve seals.
Once the oil lite went off and reached good temp... it didnt show signs of smoke after restarting.
It did look blue but it did not have the burnt oil smell. So I wonder what it was.
Thanks to everyone for your helpful comments. I am very grateful you took the time.
If it smokes when fully warm - something aint right. Valves, rings, leak somewhere that needs fixing.
The only exception would be condensation from water caught up in the exhausts - but this looks obviously like steam... all cars do it.... but also more noticible in cold weather.
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAA ngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2d wmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAn wbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFY l8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb 8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6d yISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
