Food for thought - Intake tubing
Old Jul 3, 2009 | 09:30 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
I was at home depot yesterday and this tubing caught my eye. It is made out of aluminum and is flexible. would it be wise to fabricate some intake similar to the fangs using this tubing?
Old Jul 3, 2009 | 09:46 AM
mkonei's Avatar
05 C55
might collapse it,it doesnt appear very rigid.
Old Jul 3, 2009 | 10:08 AM
shardul's Avatar
it is pretty rigid, i was trying to press it with my fingers.
Old Jul 3, 2009 | 11:04 AM
BenzoBoi's Avatar
Super Moderator
W221
If anything I would try to use it as brake ducts?
Old Jul 3, 2009 | 11:12 AM
chawkins2001's Avatar
2006 E55 AMG
That would be badass
Old Jul 3, 2009 | 11:27 AM
bassn_07's Avatar
2006 E55 AMG
I would avoid using aluminum do to heat. That thing would probably get totally heat soaked causing a hot air intake. Just my thoughts. Ask thericker, I think he already tried something similar.
URnext's Avatar
SL55 AMG
I could be wrong, but something like that would create a lot of turbulence in the intake.
Old Jul 3, 2009 | 11:32 AM
bobgodd's Avatar
2004 E55
This would be my thinking as well.
Some time ago a intake thread popped up and some members brought up the idea of using Samco silicone hoses to fab up some new intake tubing. The hoses are relatively smooth inside and they have some that have good heat resistance too.
This is the Samco store at Summit Racing:
http://www.summitracing.com/search/Brand/Samco-Sport
Old Jul 3, 2009 | 01:05 PM
str8ridin's Avatar
05 E55
Heat absorption and a non-smooth interior would be two very good reasons not to use this. But I like your thinking. The E39 M5's have something similar to route air from from the lower front bumper up to the engine bay for cooler air. Not sure if we have room to do anything similar in our cars.
Old Jul 3, 2009 | 01:16 PM
JustPete's Avatar
CLS55 AMG 030
Have to agree with everyone else here. You don't want to use that. All those nice little aluminum fins are going to capture heat on the hotside and it's going to migrate to the cool air running through the inside. Will work just like a heat exchanger.
Remember ... heat always runs from high temp area to cool. The exterior will undoubtedly be the high temp area.
Old Jul 3, 2009 | 01:23 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Maybe another way to go is wrapping the current tubing with heat sheilds or some type of insulation.....
Old Jul 3, 2009 | 01:27 PM
str8ridin's Avatar
05 E55
Like gold? Apparently the McLaren F1 usues gold because it reflects heat very well!
Old Jul 3, 2009 | 01:30 PM
MB_Forever's Avatar
LOL..... that maybe an overkill
Old Jul 3, 2009 | 03:59 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
don't forget to throw in the fabric sheets once you install it
Old Jul 3, 2009 | 04:57 PM
Thericker's Avatar
V12-Biturbo
Cool link! great prices, 1 could custom fab-up a trick CAI, maybe help reduce a little Intake Heat IE CF laid inside & out, or just add some pizzazz to OEM setup, chk out these Carbon Fiber wrapped alloy 3" Couplers
Samco Sport CF76 - Sport Hose Coupler, Carbon Fiber, Natural, 3 in./76mm Bore, 3 1/8 in. Length, Each $19.50
Old Jul 3, 2009 | 09:24 PM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
lol my friend used that to make an intake for his 140hp Infiniti G20 and it collapsed. we were in highschool
Old Jul 3, 2009 | 11:09 PM
shardul's Avatar
Thank you sir
Well so much for that idea.
Close this thead.
Old Jul 4, 2009 | 12:34 AM
DFW01E55's Avatar
'14 ML BT
Originally Posted by shardul
Thank you sir
Close this thead.
Don't give up so easily.
I doubt that dryer venting is going to collapse.
Due to what?
Internal (suction) pressure? Bull.
If heat soak is a problem, wrap it with heat reflective tape.
The turbulence would be more of a concern than collapse.
However, the expanded intake volume should more than compensate for the turbulence.
(Yes, it's true, I cannot provide any science to support my position, but neither did anyone else and I supported my comments with pure conjecture.
Old Jul 4, 2009 | 09:02 AM
JustPete's Avatar
CLS55 AMG 030
Thank you sir
Close this thead.
That stuff isn't going to collapse on the "lower" pressure side of the intake (Pre-filter) Between the filter and intake could be another story as the filter clogs up.
I wouldn't use it though because it will be a much more efficient heat sink.
I tested a very simple theory yesterday and it worked fantastic. Internal tube temps dropped about 25degrees.
https://mbworld.org/forums/w211-amg/...t-results.html
