Anybody try Techron ?
Old Jul 21, 2009 | 02:05 AM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
Anybody use Techron fuel cleaner in our car ? is it ok and does it work ?
I bought the one that cleans 20 Gallon .... just want to be safe ...
Thanx !
Old Jul 21, 2009 | 02:27 AM
holycaoAMG's Avatar
A Car
Though i do have a different car than you, I can asure you that the Techron Concentrate is OK and approved for MB's.
It actually does a great job cleaning the fuel system and i highly recommend it to anyone.
Old Jul 21, 2009 | 01:59 PM
CharlyE500's Avatar
Thanx !
Old Jul 21, 2009 | 02:09 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
There was a thread in the w203 section about using techron and its benefits. No negative reviews thus far. I have used it myself and am happy w/ the results.
Old Jul 21, 2009 | 09:20 PM
GGM's Avatar
GGM
2008 E350
Thanx !
FYI--Chevron and Texaco gas both contain Techron. I only use Chevron gas. Don't know if you have it where you are but you might consider using it regularly.
Old Jul 21, 2009 | 09:34 PM
iblaho's Avatar
A thread about additives had a post that said that the fuel treatments included in the gas at the pump are equalivalent to spitting in the gas tank. Some said use a fuel cleaner twice a year while others said every 3,000 miles. No reports against using it in the prior threads.
Old Jul 21, 2009 | 09:41 PM
holycaoAMG's Avatar
A Car
I fill up with chevron and use techron every 3k miles.
From my experience I actually gained 3 mpg and the engine feels a lot smoother, since the injectors are cleaned throttle response is better too.
Old Jul 21, 2009 | 09:43 PM
M-bENZ's Avatar
Corrolla
I've been using that since I bought the car .
Andy
Old Jul 21, 2009 | 10:19 PM
NDF55's Avatar
2006 E55 2004 Audi S4 (gone and missed)
I prefer "Seafoam" I've read quite a few threads on many different enthusiast forums that say the cleaning power of seafoam is much greater than that of Techron.
Old Jul 22, 2009 | 01:02 AM
RenntechE55's Avatar
CLS55 AMG 030
So Techron is a fuel cleaner , so is it basically like a injector cleaner like the ones at checker auto parts?
Old Jul 22, 2009 | 07:48 AM
itsmeek's Avatar
Nissan GT-R cobb/midpipe/ic piping/wastegate actuators/tials
NDF55, do you use the seafoam in the gas tank or via vacuum lines to the engine? If you do the proper way w/the vacuum lines- you must replace your sparkplugs afterwards. Too much of a headache imo.
Old Jul 22, 2009 | 07:58 AM
mkonei's Avatar
05 C55
ive always been happy with Lucas. I buy it in the gallon jugs, and use it every two or three times i get fuel.
Old Jul 22, 2009 | 09:34 AM
NDF55's Avatar
In the gas tank, I agree with you putting it in through the vacuum line would be too much of a headache. But, I am curious as to why you feel the plugs need to be changed if i did decide to do it this way?
Old Jul 22, 2009 | 09:43 AM
itsmeek's Avatar
The seafoam will remove the carbon deposits which may and probably will reattach to the spark plugs thus fouling them. It's more preventative then anything. An oil change is also recommended if you add the seafoam to the oil for the same reason.
Old Jul 22, 2009 | 01:23 PM
CharlyE500's Avatar
Just put a bottle of Techron for 20 gallon this morning. Hope will get better MPG and clean better. My car has already 76K, its about time to do some maintainance. Since the fuel filter can not be replace without replacing the gaz tank, I better use Techron every 3k miles.
Old Jul 22, 2009 | 02:01 PM
jturkel's Avatar
02 C32 AMG
+1
Old Jul 22, 2009 | 02:18 PM
NDF55's Avatar
OK, so when your pour the seafoam into the gas tank where does the carbon go when it's cleaned out of the fuel system? Does it go into the catalytic converters, and clog them up shortening thier lifespan? Or does it just get burned off?
Old Jul 22, 2009 | 03:21 PM
slownrusty's Avatar
'06 E55 K2
Techron is strongly promoted and used in the Porsche circles, I would have no issues using it on my E55.
Old Aug 6, 2009 | 11:41 AM
Jen_Kenne's Avatar
my wife wild, but she loves every minute of it.
Thumbs down
Anybody use Techron fuel cleaner in our car ? is it ok and does it work ? I bought the one that cleans 20 Gallon .... just want to be safe ... Thanx !
There are several strengths on the market. In addition, there is 'some' Techron in Texaco/Chevron gasoline.
Old Aug 6, 2009 | 12:04 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i tried it on 203 but didn't feel any difference...
extra bottle sitting at home... will try on 211 later...
Old Aug 6, 2009 | 01:29 PM
CharlyE500's Avatar
I just finish the entire tank of gaz with techron so far dont feel much different. I guess i got to do it every oil change.
Old Aug 7, 2009 | 08:26 AM
Jen_Kenne's Avatar
I fill up with chevron and use techron every 3k miles. From my experience I actually gained 3 mpg and the engine feels a lot smoother, since the injectors are cleaned throttle response is better too.
What brand gasoline were you using before you ran a tank of Chevron though your car? 3 mpg is an impressive improvement.
Old Aug 7, 2009 | 09:05 AM
madgoat's Avatar
2006 E55
I guess that is ok if cleaning is what you are looking for...
If you are looking for a best fuel for performance do not use Chevron w/Techron or Shell gas.
We tune/R&D(non MB) alot of stock/modified vehicles and cars that have Chevron/Shell make the least power. We recommend BP,Amoco, Sunoco, or Mobile. We have actually drained R&D vehicles tanks and replaced the fuel that had Shell gas in them because they made less horsepower than stock untuned.
Old Aug 29, 2009 | 05:35 PM
FLSL55's Avatar
SL65
+1 madgoat
Supra made 20+ more hp when I used mobile 1. My C6 made 11 more rwhp with Mobile as well.
Old Aug 29, 2009 | 05:56 PM
str8ridin's Avatar
05 E55
Why do you think that is?
