Evosport line-lock review
My first impression of the kit is great: the components are all of highest quality, and the instructions are well-written (and in English !!!)
The install went fine; the hardest part of it was the STAR/DAS bleed sequence....bring brake fluid !!!
I haven't decided on a permanent location for the button, but you can see the race position and general storage position:
Race:
Storage:
Operation is straightforward: depress brakes, hold button, release brakes. You are now gripping by the front brakes only, facilitating the burnout and salvaging the rear rotors.
The new tire setup I'm running requires a long 3rd gear or 4th gear burnout to dead hook, and this kit is an immeasurable aid in achieving that.
The looks from the staging lanes when a Benz murders a burnout: priceless.
I would recommend this kit to anyone who considers themselves a track regular.
. A couple of my tech buddies advised against it in fear of damaging the SDS pump (not a 100% positive this is the correct name). What are your thoughts on this? Over long term use do you see this happening? Also, what would happen if that button was accidentally pressed while every day driving? Just questions I have that has kept me from installing.BTW...what was your 60' time on that launch? It seemed like you dead hooked on that one.
Is that your e55 with the screaming S/C?
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
I got on tape a guy in the back ground yelling "WOW" and then a little girl going "Look at all that smoke"
http://www.youtube.com/watch?v=wpOjEbBBzGU
Then this smoky burnout
http://www.youtube.com/watch?v=nryISWXl2nM
Wayne good stuff, I need to do Line locks soon. I tell you the longer I do a burnout the better my car hooks. Seems you are having the same results with the hot burnouts.
The pass in the vid was the second one on a new set of tires, so I was launching a bit softer than normal, feeling for traction. I think it was a 1.67 60'.
I have seen a warning message if the brakes don't get fully depressed before engaging the line-lock. It goes away after a key cycle and doesn't return.
I think we have lifetime warranty on SBC pump, but I don't see this causing problems - this is a well-designed kit with no corners cut. Good job, evosport.
The solenoids will engage, if pressed while driving. The only harm I see happening is if you press and hold the button, THEN try and brake.....no brake fluid going to calipers could be interesting.
I drive the car daily, and have put about 2500 miles on the car since install with no issues besides tire wear.
