Crank key help
Old Aug 11, 2009 | 11:13 PM
lowprofile's Avatar
E55
Renntech, some pics here would help determine what really needs to be done to correct the situation. Of greater importance, you need to figure out what caused the issue before attempting another install.
I never heard of a crank and key being one piece, and would have to see it to believe it. If replacing the broken key is not a option, you could have the the pulley pinned with a dowel. Any shop that has added a s/c to a LS1 will be familiar with the process.
Good luck.
Old Aug 12, 2009 | 01:04 AM
RenntechE55's Avatar
CLS55 AMG 030
well I have no idea what to do now, I reinstalled it and every thing was fine took it for a mile round trip test drive came home checked it and it wall all good , installed my Johnson pump and then went to go get a clear hose to bleed the line I get about two miles from my house and the pulley came out again. I have no idea what is wrong like I said the key tip was broken, another member said that has happen to him so I just did what he did torqued the **** out of it but still the bolt came out. will I pry need a new crank?
Old Aug 12, 2009 | 01:31 AM
CLS55 AMG 030
BTW: I had to shave down a little pc.of metal in order to get the water pump pulley to fit is that normal? thanks
Also please explain the flexplate procedure (what and what not to do) to tighten the pulley bolt. if it turns out i can still use everything and not get a crank then i'll try to lock the flexplate.
Old Aug 12, 2009 | 02:01 AM
aleksandar1099's Avatar
Top Answer: 1
Mercedes
Hey Renntech,
As per others advise, it takes A LOT!!!!!!!!!!!!! of force to tighten the bolt, not exaggerating, it takes a lottttttt more than you would think it would take.
Btw, new crank is around 4k, and a HUGEEEEEE pain in the azz to install, as in take apart the entire engine....
Honestly, take it by hooleyboy at dyno comp and let the see what can be done! IMHO..
I wish you the best of luck!
Old Aug 12, 2009 | 06:49 AM
komp55's Avatar
ML550
The woodruff key is replaceable - assuming the keyway on the crank hasn't been damaged. It's number 11:
Old Aug 12, 2009 | 07:52 AM
James@ACG's Avatar
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
I know your trying to learn from this experience but honestly I think its time for you to bite the pride and take it into someone who is familiar with the vehicle. You really have no idea what is damaged at this point and if you continue to do what you are doing it can begin to cause some major damage to your vehicle that I'm sure you care a lot about. If the damage hasn't been done yet, it will be if your trying to guess at it and just ignore what has happened. Regardless of your decision good luck, and if you really don't want to take it in anywhere post some pictures, or give one of us a call.
James
Old Aug 12, 2009 | 09:29 AM
  #32
sales@eurocharged.com's Avatar
SPONSOR
C63S
Sorry I didn't see this sooner.
This is what I would like to do / have done:
1. Ship the pulley kit back to me via overnight delivery. I will ship you a new kit via overnight delivery as well. After two bad installs, I can only wonder if the pulley is out of balance now. Instead of risking it, I would rather replace it to be certain. Send me the crank bolts and crank pulley, I will send the same.
2. Please find a local shop that can do the install for you. I personally installed a crank pulley on my car to later find out I did it wrong. It's not worth the risk bro.
We do a couple of installs a week and I can tell you that when I'm helping our tech trq down the crank bolt (Vadim was right, it's a two man job!), I get pulled across the shop floor while he is trq'ing it down. It's not easy to do.
Hope this helps!
Jerry
Old Aug 12, 2009 | 09:39 AM
  #33
CLS55 AMG 030
Thank you all very much. I have decided not to touch it until I get some advice I sent a email to Chris at floored Fab. , hooleyboy, and Jerry. They all seem like very knowledge guys and I'm sure I can get it fixed. I'll send the first and second bolt , along with my belt. Thanks
Old Aug 12, 2009 | 09:43 AM
  #34
SPONSOR
C63S
Thanks! Looking forward to getting you back on the road.
Old Aug 12, 2009 | 09:52 AM
  #35
hooleyboy's Avatar
Former Vendor of MBWorld
C55,SL55,C63
N006888 005005 woodruff key as seen in pic above #11
A112 052 10 03 Crankshaft gear as seen in pic above #17
I've these are the only parts you need it would be around $200
Installing them would be the hardest part as you got to take off a bunch of stuff.
Old Aug 12, 2009 | 09:54 PM
  #36
BlackBeast'06's Avatar
'06 cls 55 amg, '03 Range Rover HSE, 88 Firebird Formula
I have the exact and I mean exact problem pulley was installed and it came off in about 350miles and when it did it sheared off the crank key. Now can't get the pulley to stay on. As many others have stated its can be a very expensive fix..MB is saying $14k to fix the problem. I hope WE can find a less expensive fix.
Old Aug 12, 2009 | 10:30 PM
  #37
sneakyneon's Avatar
Bicycle
At your own risk:
Transmission lock method.
Take one of the flex plate bolts out, replace it with one that is 2 to 3 inchs longer, It will bottom out leaving the extra 2 to 3 inchs exsposed, as you rotate the pully around this extra will hit the side of the trans allowing you to tighten the bolt properly.
Its what I did. It worked fine for me, but like i stated its at your own risk. I would prefer a grade 8 or harder bolt. make sure and lock tight the flex bolt when you replace it. You must have a torque wrench to do this job, none of this thighten the !@#$ out off it.
Old Aug 12, 2009 | 10:54 PM
  #38
CLS55 AMG 030
What pulley did you use? who did the install? trust me I wish I knew how to fix it cheap.
Old Aug 18, 2009 | 08:58 AM
  #39
oslowley's Avatar
Originally Posted by hooleyboy
If just the woodruff key is knocked off. I think that can be replaced. Lets hope for the best that that is all the damage that has happened.
Note: From what I know to get at the woodruff key you are going to have to take off the timing chain/case and basically the whole front end of the motor. I would thing the Supercharger and maybe even the heads or at least the valve covers have to come off so you can expose the timing chain at the camshaft gear.
Needless to say its an expressive fix part and labor wise. If this is all that has happen. Talk to John or Andrew over at Schumacher Mercedes and tell him Hooley sent you. They for sure can help you.
I know what you are going though. If you need any help feel free to contact me or Dyno-Comp.
My pulley broke my Woodruf key, took over 10 man hours to tear down and replace. All for a part that costs less than $5, thankfully I have an aftermarket warranty.
Old Aug 18, 2009 | 09:01 AM
  #40
oslowley's Avatar
Shaving down the water pump is standard fare, I had to do the same, no biggie.
Old Aug 18, 2009 | 11:53 AM
  #41
hooleyboy's Avatar
C55,SL55,C63
a while back I toasted a pulley, I took it to the dealer and waited in the waiting area for an hour and a half to hear the verdict. I got lucky and they were able to just clean out some shavings and file down one small area so the keyway on the stock pulley could go back on. I got lucky. The SA was telling me if this way failed I was looking at about the same labor hours to totally replace it.
If it only took 10 hours of labor,. I guess thats not that bad when you compare it to what could have happened. These are tough cars no doubt about it.
Old May 21, 2024 | 02:06 PM
  #42
AMGmann76's Avatar
96 c36/04 e55
Crank key
put a smaller crank pulley on but getting a little wobble, I can see when I pulled the seal off I might have damaged the key, how would I replace that?
Thx
Old May 21, 2024 | 02:47 PM
  #43
S_Holford's Avatar
2020 Jeep Gladiator Mojave, Tesla Model 3 Performance, Tesla Model X
Thx
See below thread. It’s an M113, not a K, but still applies.
Make sure you torque the crank pulley properly upon install and it won’t back off.
https://mbworld.org/forums/clk55-amg...woes-m113.html
