New Wheels and a few other mods. PICS Included
Old Aug 15, 2009 | 07:38 AM
Hazim's Avatar
2003 E55 AMG
To protect the wheels from any damages your air pressure should be not less than 45 psi
Old Aug 16, 2009 | 02:26 AM
Blownbenz's Avatar
2005 E55
Are you sure about that? That seems really high. factory settings say mid 30s
for PSI. Anyone else here running 45psi in 20 inch wheels? Is this what i should be doing.
Old Aug 16, 2009 | 02:32 AM
jturkel's Avatar
02 C32 AMG
if you look carefully on the tire's sidewall, it should indicate somewhere what the optimum tire pressure (or range of pressures) is.
45psi sounds absurdly high. in my door jam, it says the rears should be at 35 and fronts at 32 (for a c32 though). if you look at your door jam, it will also give you an idea of what it was supposed to be for the stock tire. 45 does sound way too high though. fear of explosion IMO
Old Aug 16, 2009 | 10:23 AM
Hazim's Avatar
2003 E55 AMG
You are correct look on the sidewall for the highest psi the tire can take, and DO NOT go higher than that.
The 35 and 32 PSI are for the 18" wheels.
I could be wrong
Old Aug 16, 2009 | 12:32 PM
Fastgreek's Avatar
2005 SL55 2022 GLE350
beautiful.............
