Bad news
CLS55 AMG 030
Thanks for all the support , any takers for checking out the engine? I have to give props to Chris if it wasn't for him , I wouldn't have been able to afford to do this. I really hope this all works out and this engine checks out. I haven't driven my car in almost three months , and was excited to get the new mods on , I could always sell the $4300 in mods I bought in the last couple months but then I will just back to step one on the Moding chart
"key way" not the key has been widened from the trauma or vibration, when the pulley flew off. I can continue to attempt to remove the gear, but I think its fused to the broken key or crankshaft. And to remove it will require grinding and cutting which may damage both the crankshaft and or gear."
I am also not entirely sure why the pulley came loose in the first place? I know you have two different length / type bolts used ... was this tried to try stop the pulley from coming loose or did this cause the problem?
Would be handy if they made this pulley fit onto the crank with splined slots like the drive shafts - would not have any of this milarky.
#32
Really sorry to read of your misfortune. I agree with the others that said it would be more sensible and efficient to install a replacement engine. There are some for sale on eBay right now that you might want to check out too:
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
http://cgi.ebay.com/ebaymotors/Merce...Q5fAccessories
http://cgi.ebay.com/ebaymotors/2004-...Q5fAccessories
Also, you might try to locate one through www.uneedapart.com This links to salvage yards around the country and the sellers will respond if they have one to sell. GL getting her back on the road quickly and as inexpensively as possible. We all feel your pain.
#34
CLS55 AMG 030
What does he mean by "gear" here? Is he talking about the pulley? I assume the keyway is the woodruf key way for the pulley to fit onto? What is fused to what here? Sorry for the questions but I don't understand what "gear" is damaged - although it sounds pretty serious. The pulley came loose this would put major strain on the woodruf key and slot, and almost surely destroy the pulley key... the crank would also get some stick but thought it might hold out.
#35
CLS55 AMG 030
#36
2005 BLK/BLK E-Double Nickel.
Found these in your price range
2005
Engine
Mercedes S Class S55 7-04,RWD,5.5L,AOD,AM G D90024 $5000 Ken's Auto, Inc. USA-ND(Strasburg) E-mail 1-800-950-1402 1372
2003
Engine
Mercedes CL Class 215 Typ, CL55- ONE YEAR WARRANTY-58900 58,900 A CL666 $3800 Alpha Used Auto Parts USA-TX(Houston) Request_Quote 713-941-3377 / 866-941-0651 1422
2004
Engine
Mercedes CL Class 215 Typ, CL55-ONE YEAR WARRANTY-61000 61,000 A CL125 $3800 Alpha Used Auto Parts USA-TX(Houston) Request_Quote 713-941-3377 / 866-941-0651 1422
2005
Engine
Mercedes CL Class 215 Typ, CL55 (5.5L)-ONE YEAR WARRANTY-59600 59,600 A $3800 Alpha Used Auto Parts USA-TX(Houston) Request_Quote 713-941-3377 / 866-941-0651 1422
2003
Engine
Mercedes CL Class IN CAR NICE 70K $3300 Long Island Exports USA-NY(Deer-Park) Request_Quote 631-392-1857 Request_Insurance_Quote
Engine
2003
Engine
2004
Engine
2005
Engine
2003
Engine
#37
CLS55 AMG 030
Well it if it sounds to good to be true then it is. The CL engine for $4500 is for the block only so the search continues..........
#39
CLS55 AMG 030
#42
CLS55 AMG 030
#43
2015 S212
2 CRITICAL steps that many of us (me too) learn too late:
1 - Line up the key into the key way and make sure it slides in smoothly.
2 - TQ properly.
Seems simple, but it leads to major change if somethng is off.
#44
CLS55 AMG 030
#45
2015 S212
Make this a project and use all the knowledge here to build yourself a bad ride. A used motor can only bring trouble without all the gains. At least a re-build can be custom.
REPLACE THE PISTONS!! FORGED FTW!!!!
#48
An opinion here, but in my experience crank pulleys gone awry often lead to other trickle down issues in the motor. In this particular instance, it may not be the case, but having that crank pulley loose could have cause all kinds of wierd things to go wrong inside the block... bearings, seals, who knows. I don't think I'd try rebuilding unless you have a big cash reserve in case things aren't all as they seem - which doesn't seem to be the case in this instance.
Get yourself a new shortblock... and then maybe tear down the old one and see what you find. You may be able to salvage it or sell off some bits to recover the costs of the new (used) shortblock.
-m
-m
#49
2015 S212
No need to PM, lets keep this public. Our cars are all gaining in age and rebuilding with trick parts is gonna be the wave. Forged Pistons are the main change I would make in the bottom end, so why not do it now. The difference is massive (IMO).
Maybe others can chirp in on what else could be done while it is apart. I'll help all I can just to enjoy and learn, so PM away. I just wanted this to be positive, instead of us just giving in on the beast.
