03 E55 goin into limp mode while driving
When this happens, go to the dealer and ask the SE to get in the car with you so he can see hear and experience it. Because, if the computer 'doesn't throw a code' you are beat until it happens again. This is dangerous and I hope it gets taken care of. Good Luck.
Because of this issue, I just had the transmission fully rebuilt with some updates. The first time I floored it after the rebuild. Same exact problem.
I found this post and called my trans guy and he said that he did replace that electro plate connector.My opinion is that it is trying to shift to 1st gear. Because when it shifts it feels like it starts to lock up the back tires, but then goes instantly into limp mode.
My temporary fix is to floor it up to speed, then shift the car into neutral for a few seconds then bump the gas pedal and shift back into drive. This will work for temporary until I FIND the PROBLEM.
This makes me want to cry really. Just bought the car with 95k, and my SC idler pulley destroyed itself, trans limp mode issue, and the passenger side midrange speaker cuts in and out, all started after I got to Michigan (home) from Florida where I purchased the car.
