Why does my car think its X mas?
Old Sep 21, 2009 | 05:14 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
It must be, that all of the sudden these goodies came in today.. 82mm TB, Mezaire 20GPM pump (what a beast at 7lbs!), and a custom made light-weight water pump pulley. (see pics).. Stock water pump pulley is 15 ounces and most of the aftermarket kit pulleys are around 22 ounces, if I recall.. Well, this one is only 8 ounces. So, about a 70% reduction in rotational weight off my water pump.. Is this a must mod, well it is for me. I guess it was just one of those little things that bothered me.
Oh yeah, then last Friday before the last LET tune box shipped out of Houston to California, I was able to acquire another reflash from Jerry. Even at 500 RWHP , still had another 10-15 very safe HP gain above 3000 rpm. Did not expect to feel the gain but damn,, I was wrong. I had to jump across four lanes from a 30mph roll and now I think I know what the art of drifting really is..lol
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Sep 21, 2009 | 05:17 PM
mekantor's Avatar
2003 E55 AMG; 2013 GL550 4Matic; 2003 CL600
Are you making a bracket for the pump? Shardul and I put that one on his car
Old Sep 21, 2009 | 05:29 PM
V12Godspeed's Avatar
Your worst nightmare...
That mod (TB) should wake her up more
Old Sep 21, 2009 | 05:40 PM
kjlindgr's Avatar
Viking War Ship
What TB is that? I know there was some talk about another much larger (and cheaper than aftermarket) OEM TB bolting up but nobody was coming forward with a part number.
Old Sep 21, 2009 | 06:27 PM
azncantonw211's Avatar
2005 E55 & 2007 335iC
I think it was from an Audi....or i'm just high
Old Sep 21, 2009 | 07:02 PM
mekantor's Avatar
I dont think you're high, Im reading something about the Q7 having a 82mm Bosch, and a RS4 having a 90mm Pierburg throttle body.
Old Sep 21, 2009 | 07:29 PM
PLATINUM SPONSOR
2003 CL55
mekantor Are you making a bracket for the pump? Shardul and I put that one on his car
Yes, have to make a bracket but have not designed it yet. Plan to use HDPE (high density polyethelene) for the bracket.
kjlindgr What TB is that? I know there was some talk about another much larger (and cheaper than aftermarket) OEM TB bolting up but nobody was coming forward with a part number.
The part number has been removed, so not sure. It has a bosch electronic number but that can be used on many TB`s. I have to do more re-search and see if it is the model I need. Have to fabricate an inlet bracket but that is easy.. Going to plug it in and see if my electronics will open and close it to start with.
azncantonw211 I think it was from an Audi....or i'm just high
What makes you think that? From and Audi, not that you may be high..
V12Godspeed That mod (TB) should wake her up more
I hope so but hope it works first.
Old Sep 21, 2009 | 09:14 PM
Forrest Gump 9's Avatar
shrimp boat
Where did you get the pump and the tb from?
Old Sep 22, 2009 | 02:18 PM
PLATINUM SPONSOR
2003 CL55
Summit and Jeggs carry the pumps. The TB came from AMS (Vendor here) but it seems to be for an Audi. Waiting to hear what the numbers I posted ring up.
Old Sep 22, 2009 | 04:26 PM
320 dreamer's Avatar
2003 porsche 996 turbo
are you looking to sell the y splitter and tubes off the oem throttle body? i would be interested
Old Sep 22, 2009 | 06:12 PM
Mathmik's Avatar
14-F Sport, 07-CLS63 2003-HUMMER 2004-Suburban 2008-MAX 2005-YZF R1
What you plan on doing with it?..... I thought of buying one too and playing around with moding it!
Old Sep 22, 2009 | 07:08 PM
PLATINUM SPONSOR
2003 CL55
Sorry , not yet. I am going to list my oem 74mm and bellows soon. No extra splitter pipe though..
__________________
www.ultimatepd.com
