bad O2 sensor causing misfires and PTE tstat failed
Old Oct 12, 2009 | 06:04 PM
e55 baller's Avatar
W221 S65 AMG
Just had some warranty work done, a faulty 02 sensor was causing cyl 1, 3, 4 to misfire, weird. Didn't think it could do that.
Also had to have my tstat replaced as the PTE one failed. Strange.
Old Oct 12, 2009 | 06:15 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
I would think a MB dealer would find a running cool condition and blame a tstat, if that was the case.
Old Oct 12, 2009 | 06:53 PM
e55 baller's Avatar
W221 S65 AMG
I also got codes that it was running too cool then got a coolant leak, MB said it was tstat related? hmmm.
Old Oct 13, 2009 | 03:12 AM
Marcus Frost's Avatar
Real Cars
Modified t-stat + big H/E will throw those codes... I get a code now and then for car not getting up to operating temp with just my H/E...
-m
Old Oct 13, 2009 | 11:16 AM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
i've been getting a coolant leak from the high pressure system too. can't quiet narrow down what's leaking.
i get those codes occasionally too especially in the cold, but thats just what you have to deal with if you want to run a cooler TSTAT
Old Oct 22, 2009 | 10:36 AM
Mrbig's Avatar
Really ok, my car too was running great and then out of the blue check engine came on and codes read misfire, u think its from car running cooler no real issue i was kinda of nervous. Or the pte went bad ?
Old Oct 22, 2009 | 11:59 AM
mekantor's Avatar
2003 E55 AMG; 2013 GL550 4Matic; 2003 CL600
I've got an occasional miss and a 0106 code whenever that happens, which is like a O2 bank 2 rich IIRC, also get high idle / running rich codes. Were you having similar issues?
I was thinking bad coil, but maybe I'll change that sensor instead.
Old Oct 22, 2009 | 12:51 PM
Mrbig's Avatar
See my issue is i have no cats so im not sure maybe a plug or coil maybe !!!
