Problem with my E55 Vibrating
Old 10-14-2009, 06:05 PM
umi
umi's Avatar
E55k AMG
When i drive the car at low revs, the car shakes/vibrates it seems to be coming from the middle, when i step on the gas it goes away but it does come back. Any suggestions what it could be i was thinking maybe gearbox
Old 10-14-2009, 06:17 PM
RenntechE55's Avatar
CLS55 AMG 030
ya I have the same problem , but havent figured it put yet.
Old 10-14-2009, 06:20 PM
umi
umi's Avatar
E55k AMG
it scares me to drive it as i dont want to cause any severe problems with it, could it be gearbox or just my driveshafts
Old 10-14-2009, 06:21 PM
CLS55 AMG 030
rereading the post are probs sound a little different.
Old 10-14-2009, 06:38 PM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
put the car in park and rev, it if the vibrations are present then it is the tranny mounts. Do the procedure in neutral to confirm problem.
Old 10-14-2009, 06:45 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
It might be the engine and transmission mount... what is your car mileage ?
Old 10-14-2009, 07:34 PM
GLK4MATIC's Avatar
GLK Matte Silver|MB Arts strut tower brace|MB Arts rear brace|Shaved door and bumper trim|K&N's|
Possibly could be the center driveshaft mount/bearing.
Old 10-14-2009, 07:54 PM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
maybe its the flex disks -- they dot ear out easily but ever know with these torque monsters.
Old 10-15-2009, 04:57 AM
umi
umi's Avatar
E55k AMG
100k
Old 10-15-2009, 05:30 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, LRD4 HSE, R107 280SL
I would say bearings and / or mounts with that mileage.
Old 10-16-2009, 01:15 AM
mekantor's Avatar
2003 E55 AMG; 2013 GL550 4Matic; 2003 CL600
misfire?
Old 10-16-2009, 11:24 PM
zivicirl's Avatar
C63
balance shaft?
Old 10-17-2009, 12:03 PM
izzyz28's Avatar
2004 E55 AMG
I just noticed this on mine. It does it in drive and it neutral, but ONLY WHEN COLD. Once the engine has fully warmed up it is smooth as silk, but for the first 10 minutes of driving it vibrates pretty good. This tells me that either engine begins to run smoother once it's warm(which is definitely true to some extent), or there are parts like the mounts or exhaust hangers that need a bit of heat to become more pliable.
Old 10-17-2009, 01:13 PM
nick 55's Avatar
GL550, C55, 335i Coupe, vintage Mustang
Originally Posted by zivicirl
balance shaft?
V8s don't have balance shafts. At that mileage, I would start with a transmission mount, and then move to motor mounts.
Nick
Old 10-17-2009, 05:40 PM
reitmeid's Avatar
2005 S55 1982 300dt
I'm not sure what year yours is, but the glycol transmission contamination issue can lead to some low speed shakes. This is from the service bulletin:
SUBJECT:
Model 211.026/065/070/076/082/083/265/276/282/283
Equipped with 722.6 Transmission
Vehicle Jolt at Constant Speeds or During Gentle Acceleration When Torque Converter Clutch is Applied
If you receive customer reports in the above model vehicles of a vehicle jolt at constant speeds or during gentle acceleration when the torque converter clutch is applied, and vehicle mileage is > 40,000, perform the following diagnosis / remedy
Old 10-18-2009, 11:37 AM
Hazim's Avatar
2003 E55 AMG
SUBJECT:
and the fix is???
Old 10-18-2009, 11:51 AM
Quadcammer's Avatar
96 and 08 911 turbos
If you haven't driven it much, a new radiator and a tranny fluid flush. If you've driven it since, basically a new radiator and new transmission.
Old 10-18-2009, 12:38 PM
Hazim's Avatar
2003 E55 AMG
Thank you,
Old 10-19-2009, 07:50 AM
umi
umi's Avatar
E55k AMG
quick update i revved the car up and it did not vibrate, took it out last night even when the car is warm it does vibrate at times to times, what could it be
Old 10-21-2009, 05:17 AM
umi
umi's Avatar
E55k AMG
Can anyone help me?
Old 10-21-2009, 08:01 AM
Quadcammer's Avatar
dude, this is something you need a shop to look at in person.
We can all sit here and speculate on what is wrong, but we are oceans away (most of us) on the internet.
Take it to a trusted shop and they should be able to locate the problem.
Old 10-24-2009, 07:34 PM
£ C43 £ AMG £'s Avatar
E55K AMG
Took mine to MB dealer, replaced both engine mounts/trans mount/rear flex disc and prop center bearing.
but there is still a rear vibration on light acceleration between 35mph and 55mph. Floor it or half throttle and no problem
tech said is might be a problem with the diff or a very slim chance that its drive shafts.
Old 10-28-2009, 05:10 AM
jicl55's Avatar
2003 cl55 (sold)
Have just recently had same problem in the last month or so.... At very very gentle, low acceleration, a slight vibration, like the throttle body is hesitating or something. Only at low speeds, like 5-20mph. Push the throttle a little harder, it goes away.... may be needing to make a trip to the dealer. Have 67k miles, CL55. Hopefully just the mounts, but who knows. Anybody else with similar issues?
Just to add a bit: does it when cold and warm, doesn't matter. Does not do it all of the time, but seems to be worse or more noticeable going up a slight incline....
Old 10-28-2009, 05:17 PM
eliteamg's Avatar
2014 E63S and 2015 Macan S
Mine does the same thing when I just start it and when the engines cold. RPM idle acts a little funny but then goes away when warm. I have 47k miles.
Old 10-29-2009, 10:18 PM
izzyz28's Avatar
2004 E55 AMG
I replaced the transmission mount last night with one I picked up for $20. It got rid of 90% of the vibration, which is good enough for me. The factory one I removed looked good by all outward appearances and wasn't ripped, but it was junk. Took all of 5 minutes to replace once I got the car up on the lift.
Quick Reply: Problem with my E55 Vibrating
