Latest dyno/82mm tb-airbox ,tune update
Here is the update. I added a 82mm TB (huge TB) and a CF airbox I found used online. With no tune changes, made 3 pretty quick pulls and all were within 1 hp of the dyno pulls two weeks prior with 80mm tb and stock box. As suspected, the stock exhaust is maxed out on flow.The larger TB and added air box made no measurable change above the 80mm and stock air box.. My test showed that 520 rwhp , is about max for stock exhaust.
Then Jerry/Tony with Eurocharged went to work on the power and was able to pick up 5 rwhp peak and about 15 peak TQ. Much larger gains came down low and before the exhaust flow was maxed. Right were I wanted it.
I posted the latest dyno tune chart over the previous chart. I do not have the dyno chart but I also looked at my chart over a car with same mods but with headers and our low power is the same but 3800 up,, the LT`s rock!!! Like 45-50 more rwhp!! Anxious to get those on the car!! Headers have been on a my short list for a year but noone has long tubes for me W215 body.. I emailed and contacted other LT MFG names listed on mbworld but no reply. I then asked Jerry and he said he could get them made one way or another for my 215. Good news after a year of no reponse!
My engine is now producing 48 more rwhp and about 80 ft lbs of TQ over my engine and quickest ET times of 11.61@120 mph.
I wanted to keep running on the street tires and get the lowest ET possible but track conditions have been to wet for street tires. I pulled two 1.73 60ft on street tires but hit brakes just in case I was running faster than 11.50.. Even then , the car was still breaking tires loose through first and some of second. Kept trying to get some traction to check MPH but no way with so much more power.
With so much spin and traction control over-riding the off position, it was hard to calculate. It seems I have gained 3 mph and maybe a little more but just a guess right now.
Street tires are past their limit now.. I lost my patience and plan to roll on MT drag radial II`s as daily tires now..
I hope to have headers in a week or so and will still run with cats. I am a firm beliver in keeping cats on the car..
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Yes, bone stock all original stock manifolds, 4 cats, 2 resonators and two AMG mufflers. Don`t want to hack any of that up . I expect very nice gains from the LT`s and mid pipe, now that the extra air is on and waiting.. Those 1.5" pipes coming off the manifold are big hp killers!
www.ultimatepd.com
If I were you I'd consider upgrading the entire exhaust system to optimise your car's configuration.
With the power your putting down I cant understand why are you not trapping 126+MPH?
Maybe the stock exhaust is holding you back
Why dont you just get some mid length headers like Kleemann's or something similar?
They should help you reach your goal without having to fab a set.
Thank you and thanks for the latest dyno graph verses last fall graph, when I ran the 11.61 ..
Below is my latest graph over my graph with just box tune, pulley and 80mm tb verses the mods I have now.. No new track times yet.. Not from lack of trying but even second gear rolling starts have no traction.. Next best mod will be tires, then headers. converter and ported heads later..
You can see the really nice gains down low from dyno tuning and tweaking my cooling mods some..(bigger pump and direct wire).. Also note that I gained a lot up top but it is not linear, due to stock exh. being maxed.
