Star Diagnostic How To DIY with lots o pics
Old Jul 28, 2012 | 07:44 AM
  #551
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Originally Posted by AgSilver
Before I changed my ride height I installed rear toe links and KMAC adjustable bushings. After setting the new ride height and balancing with a bubble level, only then did I have a realignment performed.
Castor: 11 deg
Front Camber: 1.6 deg neg
Rear Camber: 2.2 deg neg
Front Toe in: 1 mm
Rear Toe in: 8 mm
Keep on checking the rear toe links from time time if you don't have the updated bolts with a finer thread they will tend to get loose.
Old Jul 28, 2012 | 05:54 PM
  #552
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Thanks - - - good info. I will recheck them, although I did use LocTite during the install.
Old Jul 29, 2012 | 02:38 AM
  #553
Das Geld 2's Avatar
SL55, S500
Com Port 2 is the first thing you check!
Old Jul 30, 2012 | 01:43 AM
  #554
natrigon's Avatar
sold
used 2008 uneven from mods?
Hey all, Just bought a used 2008 e63 35k miles from a used car dealer and after notice the front left side is lower than right. Took it to a real merc dealer who said he needs to put it on the alignment rack for 200 to check but tires are worn uneven and inside almost bald.
After reading most of these threads I am now wondering if the previous owner improperly lowered the car using a mod... it looks low but not sure.
Should I take it to the Merc dealer or independent Benz guy like AGA German Auto Service in Pasadena, Ca? Any thoughts?
Old Jul 31, 2012 | 12:09 AM
  #555
taleb659's Avatar
03 SL55 AMG, 02 ML500 & 95 C36 AMG
Hey guys I read through this whole thread and its full of good information, but I could not find my answer. I have a star knockoff that was working fine when I first got it, but then I never used it for a years time. I went to scan my car today and I got this CAL 503 ERROR?
Anybody have any idea what this is and the solution to it? I would really appreciate any help; I have a SRS light that I want to diagnose.
Old Aug 2, 2012 | 01:49 AM
  #556
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Originally Posted by OCKlasse
I don't know if you 211 guys have this, but can I disable the volume speed control in my CL? Anyone know how to get there?
bump
Old Aug 2, 2012 | 03:23 PM
  #557
streetspeeder's Avatar
2006 E55 AMG
Hi Guys/Gals
I just got a C3 "for educational purposes"...::wink::
I've managed to get all the software installed Xentry/DAS, WIS etc. but have yet to try to connect to the car. I hope it will be relatively painless.
I came across this thread that may be useful to those that haven't found it yet. Its a full writeup (PDFs) of installing/using a Chinese DAS.
Old Aug 2, 2012 | 04:29 PM
  #558
shardul's Avatar
bump
should be under the comand menu
Old Aug 8, 2012 | 12:37 PM
  #559
Pewter KPA's Avatar
2004 E55 AMG
Aleks or others,
I used the 3.5 and -1.1 inclination settings on my 04 E55 last night. I was sitting in the car at the time. The drivers side came out great but the passenger side is about .3" higher front and rear.
I have read all 23 pages of this thread and as I understand it I am going to have to play with the inclination angles to get it to even out. Correct me if I am wrong.
My big question is (as stupid as it might be) in what manner am I to change the inclination angle to lower it. I know I can do a trial and error but I figured most on here would have the answer.
So if I go from 3.5 to 3.6 in the front is that going to raise or lower it?
If I go from -1.1 to-1.2 in the rear is that going to raise or lower it?
Thank you much in advance?
Old Aug 8, 2012 | 12:48 PM
  #560
rchase's Avatar
2004 E55 (sold) 2012 E350 4M
In addition to Alek's question does anyone actually know the stock parameters
Old Aug 9, 2012 | 12:11 PM
  #561
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Coming from memory:
FL 1.94, FR 2.71, Rear 2.67
E55
Right side is always higher vs front left on stock cars.
Old Aug 27, 2012 | 08:48 PM
  #562
awiner's Avatar
2003 CL55 AMG
Eek --- Chinese ballocks.... You need the CAL 872 fix. Google
Old Sep 5, 2012 | 07:12 PM
  #563
Neanicu888's Avatar
1999 Mercedes Benz E55 AMG
Anyone has a good Xentry DAS for sale with laptop new or used?
Pm me please.
Thanks!
Old Sep 5, 2012 | 09:14 PM
  #564
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
I was wondering if anyone knows if there is a menu to reset all parameters to factory defaults? My car has had an issue for some time now (Speedtronic/Cruise). When I scan, there is no malfunction but when I try to activate cruise it gives me this error.
I am thinking it thinks there is Distronic module installed and not finding it. If I could just reset everything and go from there, that would be good. The only things I have done are set to ROW, disable seatbelt warning, added parktronic and raised speed limiter to 300. I have tried backing those out but still have an issue. Tried clearing any codes already. I don't use cruise very often but just don't like stuff not working without knowing why.
Thanks!
Old Sep 15, 2012 | 01:25 AM
  #565
turbo97se's Avatar
I have been struggling using my trusty old HP laptop to run DAS It is super slow because it runs a virtual machine of DAS... it would take 5 minutes or more just to boot the virtual machine! I have tried a couple of times to migrate to a new laptop but the newer ones don't have serial. I have tried several USB to serial adapters but the only one that works is the FTDI one mentioned by someone earlier in this thread. I then fought with a couple of settings to get it to work. I thought I would do some screenshots and mini-tutorial on how to make this work. I am using a Macbook Air, but some of the instructions apply to windows machines.
1. Install the FTDI driver Latest drivers here: http://www.ftdichip.com/Drivers/VCP.htm
2. Install VMWARE - Mine was VMWARE Fusion
3. Open Virtual Machine file. I recommend copying it to your local drive if you have space. It is about 65GB
4. Start the Virtual Machine
5. Plug in the FTDI cable and you will see the screen below:
6. Select connect to Windows. You may need to install the drivers in Windows. Mine installed automatically without installing drivers on the virtual machine.
7. In the virtual machine select control panel -> system as shown below:
8. Go to Ports (Com & LPT) and select communications ports and disable all active serial ports.
9. Select the USB com port. Go to advanced and set the port to port 2.
Special thanks to Shardul, Benz-O-Rama and the dude that gave the link to the FTDI USB-Serial converter!
Here is a video of it running ... I did not pull up DAS itself since I was not connected to the car, but you can see it is fast. This is actual speed not time lapsed.
http://youtu.be/jzw8fLo_6gY
Old Sep 16, 2012 | 11:47 AM
  #566
AMG893's Avatar
2010 C63 Estate
So has anyone figured out how to activate VIM in a W211 or an ML 2010 Model using Star Diag?
Old Sep 20, 2012 | 03:54 PM
  #567
rubenramose500's Avatar
2003 E500
can the service schedule be reset using DAS i have a w211 e500 and the instrument cluster is not reseting the schedule c and i just purchased a star system and i cant figure it out yet, if anyone could help I would really appreciated it!!
Old Sep 20, 2012 | 04:11 PM
  #568
shardul's Avatar
yes i think it is under the information and communication section in the FSS ASSYST menu
Old Sep 20, 2012 | 05:19 PM
  #569
2003 E500
thanks for the response im gonna go check!!
Old Oct 5, 2012 | 03:42 PM
  #570
sp00ky's Avatar
ML350 (W166) / CLK 320 Avantgard 2002 W208
Would this also work for lowering the 2012 ML350 (W166)? The local dealer is saying it cannot be done...
Old Oct 5, 2012 | 03:44 PM
  #571
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
Probably can't be done because it doesn't have Air Suspension maybe?
Old Oct 5, 2012 | 03:53 PM
  #572
sp00ky's Avatar
It has Airmatic... wouldn't have asked otherwise.
Old Oct 5, 2012 | 03:54 PM
  #573
djrabbi's Avatar
It should work but you would need a late 2012 or 2013 version of the software...
Old Oct 5, 2012 | 03:57 PM
  #574
sp00ky's Avatar
Cheers. Should it be presumed that if their version of Star can be used on my ML and they are able to perform diagnostics using it then it must be a recent enough version?
Old Oct 5, 2012 | 03:59 PM
  #575
djrabbi's Avatar
Yeah I would wait for 9/2012 to be on the market or just wait till 2013...
You have already rated this thread Rating: Thread Rating: 15 votes, 5.00 average.
