Star Diagnostic How To DIY with lots o pics
I'm going to get the FTDI as I'm using prolific.
http://www.amazon.com/Serial-Adapter.../dp/B003N9TYW0
I use this one
http://www.amazon.com/Windows-Compat...&keywords=FDTI
And, if anyone's interested, I have a functional STAR system working here with sw 03/2012 in the Los Angeles area. PM me if you guys need any help coding or have questions in setting up your systems.
I've got a buddy that's an SDS specialist. Gonna take the unit to him and test with his laptop and connectors. If I only had a laptop with PCMCIA.....
Problem was the COM port. Windows assigned my USB adapter COM6, and Xentry is looking for COM2 (Thanks Justin and Shardul!)
Now let's see....hmmm...what can I f@ck up first??!?!?
I noted this above, but it's worth mentioning again, that I'm using a MAC for this:
Lower case f = fault was present at one time but no longer present
Upper case F = fault is current and stored
Check mark = no fault present
! = cannot communicate with the specified module
You can do it with your 220 too.
So if it aint broke dont mess with it
Castor: 11 deg
Front Camber: 1.6 deg neg
Rear Camber: 2.2 deg neg
Front Toe in: 1 mm
Rear Toe in: 8 mm
