Star Diagnostic How To DIY with lots o pics
#603
2007 CLS550 1987 420SEL Porsche 911
#604
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
#606
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Can anyone confirm there's a tire pressure warning you can activate with STAR on non-TPMS equipped cars?
"Tire Pressure Loss Warner can be activated through stardiagnose on any 2006 W211...no parts needed, it gets it's reading off ESP - just some version coding - no reading of airpressure in the IC, just a warning when the pressure of one of the tires drops too much.
Tire Pressure Monitor System is the more active system that has its own control module, 4 antennas, 4 senders and pressure readings in the instrument cluster...this can be retrofitted in any W211 and costs approx 2000USD to do so"
#607
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
you can go in the CGW and select present for TPMS. you may also have to do the same in the instrument cluster and system diagnostics.
but i am not sure if it will work if you dont have the hardware.
#610
E55 w/ goods, Z32 Project underway
Anyone know if the 'auto off' for the recirculate can be disabled. I prefer to keep it on recirculate yet Mercedes believes otherwise. Admittedly have not looked to deeply into STAR yet for this.
#612
I found all this while trouble shooting a bad N70B1 temperature sensor in the overhead console.
#613
disable Seat Belt Minder on Cls
Hi, does anybody know where i can find this option in DAS ? It is not in the same location as the W211.
It is not in instrument cluster-- special functions.
#614
So I thought I would help out a few MB brothers with a couple star diagnostic tutorials...
First, Lowering the car.
Get to the 211 Section
![](http://i90.photobucket.com/albums/k246/aleksandar1099/IMG_0014.jpg)
You will get to the main menu
![](http://i90.photobucket.com/albums/k246/aleksandar1099/IMG_0015.jpg)
Then go to Func perf by more than...
![](http://i90.photobucket.com/albums/k246/aleksandar1099/IMG_0016.jpg)
Then Chassis
![](http://i90.photobucket.com/albums/k246/aleksandar1099/IMG_0017.jpg)
Then Level adj
![](http://i90.photobucket.com/albums/k246/aleksandar1099/IMG_0018.jpg)
Then Suspension
![](http://i90.photobucket.com/albums/k246/aleksandar1099/IMG_0019.jpg)
And here is where people have problems, they just go to actuations and then lower it, IT WILL NOT STAY LOWERED this way, you have to go to initial startup
![](http://i90.photobucket.com/albums/k246/aleksandar1099/IMG_0020.jpg)
Then Initial with manual settings
![](http://i90.photobucket.com/albums/k246/aleksandar1099/IMG_0021.jpg)
Then F2
![](http://i90.photobucket.com/albums/k246/aleksandar1099/IMG_0022.jpg)
Here you will see a screen that shows the voltages which correspond to the height of the vehicle. they must be within the given ranges in the left hand column. use the + and - buttons to lower the car (In my screenshot I am in the car with a friend in the back seat, so that is why it is at 3.27, it should not exceed 3) Then hit F2
![](http://i90.photobucket.com/albums/k246/aleksandar1099/IMG_0023.jpg)
Enter in these inclination angles and if the car is within the voltages supplied in the page before, the car will accept the new lowered setting, if not it will reject it.
![](http://i90.photobucket.com/albums/k246/aleksandar1099/IMG_0024.jpg)
Now, how to activate the unlock and lock beep (honestly, one of the best mods to do if you have an older model e55
First Control units
![](http://i90.photobucket.com/albums/k246/aleksandar1099/IMG_0025.jpg)
Then Body
![](http://i90.photobucket.com/albums/k246/aleksandar1099/IMG_0026.jpg)
Then rear SAM
![](http://i90.photobucket.com/albums/k246/aleksandar1099/IMG_0027.jpg)
Then Control unit adaptations
![](http://i90.photobucket.com/albums/k246/aleksandar1099/IMG_0028.jpg)
Then national version of ATA function
![](http://i90.photobucket.com/albums/k246/aleksandar1099/IMG_0029.jpg)
At this screen you will see a pull down menu with a list of different regions on it. The only ones you need to worry about are USA with buzzer and Netherlands. If you choose USA, i will give you three short quick beeps when you lock the car and one short when you unlock it. Netherlands will give you three longer beeps when you lock the car and one long when you unlock it. Personal preference on which one you like. Then hit F3
![](http://i90.photobucket.com/albums/k246/aleksandar1099/IMG_0031.jpg)
Then F3(YES)
![](http://i90.photobucket.com/albums/k246/aleksandar1099/IMG_0032-1.jpg)
Hope this helps out some people. I really did not find a good DIY for Star Diagnostics, so I thought I would help out!
Aleks
EDIT: Info for -10 Mod added
Then Chassis
Then Level adj
Then Suspension
Then F2
First Control units
Then Body
Then rear SAM
Then F3(YES)
Aleks
#620
Does anyone know what changes to Airmatic are made with the ROW setting?
I noticed after sitting at a stoplight for a few minutes, it raises up noticeably. It didn't do this before.
