A COUPLE OF THINGS FOR THE TUNERS OUT THERE!
As I was looking over my car this weekend trying to figure out how to get some more speed out of it I started thinking and tuners please respond or anyone that may know more than I do.
I know Jangy has been working on this but can you guys (tuners) develope or find a company that can make a smaller but thicker radiator to allow for a CAI kit in its full form to pass through the radiator support?
Also, someone chime in if they know where I'm going. Is there a way to re-route the fuel line to pass through the cooling box mounted in the trunk? The idea is that you want the fuel as cold as possible before it reaches the induction system. It is my understanding that by doing this you will achieve a NOS type of reaction with the fuel being cold!
Some SCCA racers will show up to the track with an empty tank and then mix dry ice in seperate containers with their fuel.
any thoughts?
any thoughts?
PS: When was the last time you saw any dragger do this
If there were REAL gains, THIS is where you would see it as it is EASY to chill it for 8 seconds, NOT so easy for 30 minutes.
Just my $0.02
this is how new idea's come about, you throw somethings at the wall and see what sticks, some of things wont stick at all and some will make you go hmmm. I can almost bet that the rear cooling box came from a hmmm I wonder what would happen if we seperate the systems and put a cooling box in the trunk.
I only mention running the lines through something to cool it because mixing dry ice & fuel can be messy/dangerous.
E55, Supercharged Z4 (sold)
As far as intakes, why couldn't you just use silicone hoses with cone filters up front. Use a heat shield to keep it guarded from the engine and your set. You don't need it to be up in front being that it's forced induction do you?
Simple enough I would think.
You need cool air flowing into our intake system, if your IAT's get real high then your performance will suffer. Our engine compartments are so tightly sealed that even with heat shield it will not help. The holes in the radiator support are so small that if you were to open up the holes you would be able to run 3" intake tubes from the cones to throttle body.
i think the old e55 has a ac coil threw the gas line and cools the gas in the summer.It also has a heater coil in the washer fluid to keep it hot in the winter so it melts the ice once you spray it on the windshield
Funny that you metion this. Last Thursday I met up with my friend, he's own a speed shop here in Columbus, Oh, and we talked about the same issue with the intake. He does have some connection with Visteon, so making the radiator is doable. Just wondering what kinda price range are we willing to pay for an aftermarket radiator when we don't really need to upgrade.
As far as your fuel cooling need, last time I checked the Jeg's catalog, they have a little can that have the fuel line coiled inside. You can buy that can and splice it into the fuel system. Just add ice when you get to the track.
Oh yeah, my friend actually made a version of the VRP fang intake for a local guy (his screen name here is gangsterbenz, i think). In that version, he did not use any air filter, just window screen at the end ot the pipes. Work fine, but a little ghetto.
I'm not fully convinced that the tempature of the air coming from that setup would be that much higher then the existing holes. At 60mph there is a butt load of fresh air coming in from the grill etc. See what I mean? I haven't looked at it in depth though.
Either way I don't think you'd be looking to gain much power over the original setup. 10-15? Dual intercoolers is where it's at.
Becool has many different radiator setups. Range in price from $500 to almost $1,000. Quick search online shows stock is around $600 and 25.2 in. x 18.1 in. x 1.6 in. core size. I have no clue if there would be any compatibility issues though as far as materials etc. Aluminum radiators should be fine though. Just thinking out loud
1 Post
CLS55 AMG
any thoughts?
any thoughts?
Dont let the clueless and uninformed sway you away from your goal. You are 100% Correct. any forced indicted engine will benefit greatly from ingesting ambient air. A denser charge, less chance of pre-ignition detonation, more timing and more power.
These guys can make any rad in any size or configuration.
http://www.macsradiator.com/customradiators-1.aspx
3-five-five/ TUNDRA/ 07 997 cab
What they did for Josh was just to put the window screen mesh at the end of the intake tubes, no air filter. They plan to use my car as a mock up for the new radiator and intake set up. They plan to have Visteon build a narrower radiator, but thicker to compensate for the cooling system. But my initial thought was it'll not worth it.
Having said that it would still be somewhat beneficial to get colder air into the supercharger but greater benefits would be had if the intercooler itself worked better.
+1
There is no arguing that colder air will make more power. The problem with FI cars is that no matter how cold the air is coming in is the fact that it's inevitably going to get heated a bunch due to the supercharger or turbo.
1 Post
CLS55 AMG
Maybe forced induction is new to some of you guys, and perhaps thats the basis for your opinions. Cooler inlet temps will always yield more timing advance, a denser charge, less chance of pre-ignition detonation, and more power across the board. Especially when using fast burning fuels.
2005 SL600, 2016 ES300h, 2012 Hayabusa
they make small coolers similar to trans or steering coolers if you wanted to run one beneath your car to keep fuel temps ambient, but I can't imagine there would be too much gain. If you want super cool fuel, cryo2 makes a fuel bar kit that runs fuel through a chunk of metal that you then spray no2 or co2 into to cool it down. I would like to see progress on the kit for the radiator intake, I was actually thinking about this the other night, and i was trying to think of a way to have tubes/inlets in the front that give the ram air effect (I use this term loosely) and have some form of servo driven shutter to direct flow from the ground if there is rain so you don't suck up water. it would cost a pretty good chunk of change, and I'm not sure this would be worth the extra $$$. I'm mostly an r230 follower, not sure how much modification it would take to make a kit for all amg's.
So what would be the best route in having a custom radiator built? pick up a spare radiator and send it to a custom radiator shop like Mac's? for them to take measurements etc?
Mac's www.macsradiator.com says they can build one from a drawing or cardboard template. They have a form you can fill out. I'm not sure I would want to do it, again I think the intercooler is the problem, but it would be pretty trick.
