Meth Inj
Are there ANY OTHER WAYS TO ACCOMPLISH LOWER IAT's after having replaced the pump and H/E????
I assume you want to run more air through the system with a bigger pulley since you have created better flow? Are you worried the intercooler will not be able to efffectively cool the extra air flow from your head work and headers?
Methanol injection is a band-aid for inefficient intercooler systems or used when there is a lack there of. It is very effective in lowering your IAT's and preventing pre-ignition. You are better off running a large coolant tank in the trunk so the intercooler will not get heat soaked as quickly. With the trunk mounted intercooler reservoir, you can add ice to really boost the power and get your IAT's below ambiant.
