MB Arts Camber arms - enough clearance between arm and airmatic hoses?
Please reply with OBJECTIVE opinions. Thank you
Great pictures and explanation.
I wanted to purchase and install these, as I am lowered on links and getting a lot of inside tire wear especially on the front.
I agree the measurement gap for the adjustable arms is much closer than the original. The pipe could split over a long period time if the arm touches the pipe when the suspension reaches its lowest point, but if the suspension bottoms out it could snap the plastic pipe that protrudes out of the air spring. I would want piece of mind regarding this matter because a sudden large bump in the road could cause failure if it can actually touch?
If I were to test this myself to get piece of mind, I would try.
1. using a trolley jack to raise one wheel as high as possible and see how close the arm is, but I think this might be difficult given this is an airmatic setup and not a coil spring setup and the system could put more air into the spring and raise it (could disconnect the battery?) Ideally you would want to empty the airmatic system of air and allow the car to drop.
2. remove the bolt which secures the arm at the wheel/hub end leaving the chassis end bolted on and rotate the arm upwards to see how close it gets to touching the pipe.
basically to test you will need to simulate the most the wheel could travel upwards into the arch, which I would have thought have been done during the testing and production stages.
I hope this helps, please keep us posted.............. any other people used these yet?
Its hard to say without seeing it first hand, but by the looks of the pics... I think you are ok. Also the pic of the airbag is just showing the protective boot over the actual air badder itself. I personal think you got the room.
Think a problem you might run into is making sure the adjustable bolts are tightened correctly. MBZ did not have this in mind (adjustable camber arms) when they made the car. So you have to work with the space MBZ gave you. What I mean is getting a wrench or two on them can be tricky. So just make sure who ever is installing the arms does not half-*** it. When it comes to locking down the desired setup.
Agian, I think you will be ok.
I would take a similar diameter hose to the airmatic hose, splice it down the center, wrap it around where you might have a clearance issue and use tie wraps to secure.
Put some anti-seize or clearance clay(used for valve/piston clearance checking when building an engine) on the piece of hose that you just put on and drive the car for a short period of time.
Put back on lift and see if there is any contact and then you can answer the question with this quick test!!
Good luck!
Good luck!
btw, their customer service has been above and beyond ANY other hardware vendor i've come across so far!!!
+1
Good service and I am all the way across the atlantic
thanks Jay
MB camber Arms at rear and KMAC bushes upfront = a hell of lot less tyre wear and better handling
