Purchasing drag radials, how about the wheels?
Old Jan 28, 2010 | 07:59 PM
Kevinw23michele's Avatar
I am going to purchase a pair of BFG drag radials from Tirerack, and I am looking at getting a wheel to mount them on, just for track use.
Anything particular to consider, other that possibly weight of wheel? Can I go with an inexpensive MSW wheel that I use just while at the track?
BTW going with an 18" set up.
Thanks,
Old Jan 28, 2010 | 09:25 PM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
Thanks,
Just contact CCW and buy their drag pack , 16inch rear wheel with DR u cant beat it .
I think i paid 1600 for rear tires and rims
Old Jan 28, 2010 | 10:25 PM
blackbenzz's Avatar
haters crazy
Originally Posted by malakasnyc
Just contact HRE and buy their drag pack , 16inch rear wheel with DR u cant beat it .
I think you mean CCW
And if it's track only I would go with a 16" wheel and Mickey Thompson ET Street Radial or a Hoosier radial, not BFG
Old Jan 28, 2010 | 11:56 PM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
just put the DRs on your stock wheels. get Nittos and daily drive on them
Old Jan 29, 2010 | 12:06 AM
That was my original plan. But, I thought having them mounted to a different set would also extend their life. Since I drive back and forth to the track. Not sure how many miles they would last for.
Old Jan 29, 2010 | 12:43 AM
prodigymb's Avatar
Nittos would last the longest for daily driving. I drive to the track on my 16" Mickeys. Some times I keep them on for a week if I know sunday will be eventfull...
Old Jan 29, 2010 | 05:42 AM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
yes my bad
Old Jan 29, 2010 | 03:16 PM
Is the grip that the Nitto provides comparable to the MT, or do you sacrifice a lot of grip by going with the nitto?
Old Jan 29, 2010 | 03:26 PM
blackbenzz's Avatar
haters crazy
yes my bad
It's all good
You sacrifice alot of grip
Old Jan 29, 2010 | 03:30 PM
If I can find the right size MT's I am going to get them. If not, I might just go with the BFG's. With my lack of experience at the track, I need as much help as I can get!
Old Jan 29, 2010 | 04:17 PM
prodigymb's Avatar
It's all good
Yeah the 18" Nitto will not be quiet as good as Mickey thompson on the track for obvious reasons. The compound is just not as soft. However I have gotten consistent 1.72-1.75 on my nittos when i had them. Now that I got 16" Mickeys I am down in 1.6x.
However the wider Nittos used to be more consistent on the street, as you can see in my videos on youtube I was able to outlaunch everything from supras to AWD modded turbo porsches and big turbo evos and big turbo awd Vr4 galants.
The supra in one of my videos was on the BFG drag radials and he is very consistent on them too.
Old Jan 29, 2010 | 05:25 PM
Lopes80's Avatar
E55 AMG
I am going "Finny" style with these baby's, very light too, 16.5 pounds!
In regards to the tyres, I'm going with the MT, I belive the hoosier is softer but they have advised me it should not be used on the street.
Old Jan 29, 2010 | 05:44 PM
blackbenzz's Avatar
haters crazy
Isnt that only 8" wide CLK320 wheel?
Old Jan 29, 2010 | 06:02 PM
Lopes80's Avatar
E55 AMG
I think off the S class. The 255/50/16 should fit ok...
Old Jan 29, 2010 | 08:37 PM
320 dreamer's Avatar
2003 porsche 996 turbo
clk rims weigh in at 14 lbs. 7" wide and run hoosier 255/50-16 weighing in at 22 lbs for a total weight of 36 lbs!!! i found 4 clk rims for 150$ used and sold 2 kept 2 they are easily obtained
i also have a set of nitto 555r's on amg reps in 245/45-17 ill sell for 200$ plus shipping if anybody wants them
Old Jan 29, 2010 | 08:47 PM
Send me a pm if the offsets will work on an E55, or email me direct.
kevin@bwdesigngrp.com
Old Jan 29, 2010 | 10:17 PM
URnext's Avatar
SL55 AMG
+1 Best Bang for your buck and is about the lightest setup out there. Got some great 60's off of this setup.
Old Jan 30, 2010 | 07:34 AM
37 et for the clk rims. as for fitment i wouldnt know for the 55. if you are hitting the brakes try a spacer to move it away from the calipers.
on my 32 i used 24mm shank wheel bolts for a perfect fit.
if you use these on the street the hoosiers arent street legal. try the mt et streets weighing 29 lbs. 7 lbs. heavier than the hoosiers but cheaper and street legal.
Old Jun 21, 2011 | 10:35 AM
chawkins2001's Avatar
2006 E55 AMG
Looking to buy these clk 320's, and was wondering if they e55 guys need spacers?
