Go 185mm or go home!
#51
'13 Dodge Dart, '16 Audi Q5
#54
C218 CLS63TT PP Edition1, W213 E63S
205 is been used by some. although it is very risky. (with our heat, that is )
soon it will be on my friends car. i will take some pic's of it. if i saw it before he install it. or take some pic's while it is on the car.
#55
How much boost are you guys making on the 185? I know different mods will effect boost level but it would be interesting to see different boost levels with different pulleys/mods. I am going to be documenting the difference in boost going to smaller sc pulley on my car (CLK55). Even though Im just using a mechanical boost gauge
#56
#58
just to give u a small taste of what are we installing. & this one is on my car ^_^.
![](http://www2.0zz0.com/2010/02/20/13/530835835.jpg)
and here it is on my car and made all pulleys smaller to fit.
![](http://www2.0zz0.com/2010/02/20/13/483979128.jpg)
so, what do u think ???
#59
Ali- can you log IAT? That thing looks big. How small is the water pump pulley for 200mm pulley? lol. Might be overspinning it at that point
#60
2008 A8L, 2002 996TT X50, 2009 X5
His geographic elevation and free-flowing exhaust are the culprits. Someone at altitude and/or a hot climate will observe less boost on an X mm CP setup than what you'll see on a low-humidity, low-temp day at sea level. Not to mention the impact of mods, as you both correctly point out.
#61
#62
How much boost does a stock E55 make? I just put a mechanical boost gauge on my car and apparently my car only makes 7PSI
Can't wait to get this smaller sc pulley on my car
#63
Makes sense, I believe you. To capture a boost data point, are you datalogging (or watching the boost gauge) on the dyno or at the track? Not always easy (or safe) to get a proper "max boost" measurement on the street, as you really need to be WOT at the top of at least 3rd, if not 4th... IMO.
#68
![Red face](https://mbworld.org/forums/images/icons/icon11.gif)
