Supercharger Pulley Bearing...
W211 E55K, Duc 848
Has anyone found someone that can actually supply just the bearing that gets pressed into the supercharger pulley? I've been searching the internet for the past day, as I rather replace the 60 dollar bearing than buy the whole assembly for 700 some odd dollars from an OEM supplier... Just looking for someone to supply me/point me in the right direction with Nachi bearing part number "45BG07S5G-2DL" since it is the OEM bearing in our supercharger pulley. Thanks in advance!
W211 E55K, Duc 848
The bearing can be seen at this link... too bad his store doesn't work - or i would have bought it already! http://www.thefind.com/query.php?que...00044+mercedes
E55 w/ goods, Z32 Project underway
I purchased from from a private party and believe he has more but he is not interested in selling anymore the last I spoke with him. I will touch base with him again, but I paid $70.00 for the bearing and will post a DIY one of these days. No PMs please on his contact information, hate to push our relationship further after I talked him into selling me one. He uses them in air conditioning compressors if that helps.
W211 E55K, Duc 848
W211 E55K, Duc 848
Are you sure you didn't get part number "45BG07S5G-2DST" instead of part number "45BG07S5G-2DL". They seem the same but maybe the ac compressor bearing which matches ours can't handle the higher rpm output of the SC?
Go here and it should answer your question
http://www.benzworld.org/forums/w211...lley-sl55.html
Try this link also, perhaps this will clear it up for you.
W211 E55K, Duc 848
Update, I have found someone who can supply me with bearings - they aren't as cheap as mentioned in other threads... but it's a lot cheaper than the other alternative of spending 750-1000 dollars to replace the whole clutch/pulley.
Dawson718 my email is cashmoney7@msn.com
03 E55 AMG
I know this is old, but in case anybody found this by google like i did, this will be very helpfull.
A supplier of mine can get these bearings no problem. I will pass them on for what im paying plus shipping.
So $65 total.
Andrew
260-402-1357 please text
So $65 total.
Andrew
2003 SL 55
Update on Bearing replacement 4/2015
Have a found a distributor for these bearings on the supercharger Nachi bearing 45BG07S5G-2DL $51.90 US
BDI USA
1110 Inwood Rd. Suite 101
Dallas, TX75247
Office: 800-398-5662
BDI USA
Dallas, TX75247
PLATINUM SPONSOR
FYI, You have to know that on OEM plastic and or magnesium cast idler double pulleys that re-pressing a new bearing in most likely will not last. Bearings are pressed in at a interference press fit and one they go in the first time and out, you loose that required ID to get a proper press fit in the second time. the Steel oem supercharger bearings work beeter to press in a second time, as they are hard steel . That is why we designed the idlers for are own personal cars back in 2008, as the OEM ones were failing all the time.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
45bg07s5g2dl, 45bg07s5g2dst, ac, bearing, benz, change, compressor, e55, made, mercedes, nachi, pulley, replace, supercharger, w211
