3" mid X pipe and race cat install..
Old Feb 14, 2010 | 05:15 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Planed to do long tubes and mid pipe at the same time but still unable to conform any that will fit my body style.. Want to Race the Texas mile in 5 weeks but must have headers to run full boost for 29 seconds.. Frustrated would be a kind word for the dilema..
Pulled the stock mid pipe and cats down and cut the top of the primary cat off, just wide enough so a 3" 45 deg bend would weld flush to it.. Front 02`s are still in their same small 2" pipe but then it goes right to 3", a pair of dynomax race cats and X pipe.. Stock manifold outlet opening is only 1.62ID, so until those are changed, power gains are only in the 15-17 hp range..
Stock city and hwy cruise is now quieter than stock (thank the X pipe) but damn it gets loud under boost..Sounds like a high RPM race car now.. Much louder than an E55 with only second cats/resonator removed too! Much louder.. I guess you could say it is the best of both worlds now.. I did leave my resonators on too.
Here are a few pictures.. This is a $145.00 3" Pypes tunnel mid X pipe and I added two race cats for 68.00 each.. Took some welding and cutting but should be easy for a decent muffler shop to do..
Pic of passenger side front 02 . This showes the wide area cut off the top of the cat with 3" pipe welded in place of stock cat. Race cats are horizontal under the car.
Pypes mid X with cats.. Don`t eye that custom pulley holder and cheater bar either..
Excuse the mud but had to go off-roading to get on the lift that day..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Feb 15, 2010 | 12:35 PM
Luke_M's Avatar
E55, Supercharged Z4 (sold)
Where did you find race cats that cheap? Jegs has dynomax cats at around $132.99 3" in/out and 18" long. 2 way convertor although I don't know what that means yet.
Old Feb 15, 2010 | 12:58 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
Is that a pre-fab mid section?
Old Feb 15, 2010 | 02:27 PM
PLATINUM SPONSOR
2003 CL55
Opps, sorry I have magnaflow Cats. bought them here and used a coupon. http://www.performancepeddler.com/de...FQ9Jagodah6ToQ
Yes it is.. Bought it from summit and made by "Pypes".. It is a 3" tunnel mid X pipe style.. It neded a little tweaking to fit but was not bad for 141.00 bucks..
__________________
www.ultimatepd.com
Old Feb 15, 2010 | 03:25 PM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
very nice brooke. that is very very similar to my setup. i also got custom made downpipes to bolt up to the EVO headers.
Old Feb 15, 2010 | 04:27 PM
lowprofile's Avatar
E55
Very creative cutting the cat to match the 3" piping.
Old Feb 15, 2010 | 05:08 PM
PLATINUM SPONSOR
2003 CL55
Thanks. No codes either and data log shows emmissions is in ready mode.
Here is the 3" mid X pipe I bought but found it cheaper on one of the catalog sites.. not sure how they can make it so cheap, even if they used China.. It is SS and tig welded X.. http://www.pysales.com/iwwida.pvx?;i...0%201?comp=ppe
__________________
www.ultimatepd.com
Old Feb 15, 2010 | 05:23 PM
rluvsbenz's Avatar
2006 E55 Designo 1991 190E 2.3 2000 BMW 740i 1987 PORSHCE 928S4
I noticed there are two different metals used.
Whats the difference between 409 stainless and 304 polished stainless? Which ones better?
Old Feb 15, 2010 | 07:27 PM
TopGun32's Avatar
I have a custom set up as well.. with 2.5" pipes and 2.5 X pipe in place of the resonator.
I deleted 2nd cats and kept the primary untouched.
I was going to do 3" pipes, but the whole system is bottled by the exhaust manifolds and also the pipes vary from 2.5" to 2.75" on various places.
Anybody know if moving the X pipe more to the front or more to the back makes a difference in sound??
For example..I deleted my 2nd cats.. and placed straight pipes... and removed my resonator and placed X pipe.
Should I have placed X pipe on the 2nd cats locations and leave straight pipes on the resonator location?
Old Jun 24, 2011 | 12:14 PM
Gus83's Avatar
2009 E63
so whats the difference between the special X pipe and the Universal X pipe they sale?
which one did you get?
Old Jun 24, 2011 | 12:23 PM
grantwoodtx's Avatar
GLE 63S
Are you bored or something? Is it your mission in life to revive old threads?
Can you use the search function?
Old Jun 24, 2011 | 12:49 PM
Gus83's Avatar
2009 E63
i don't see why does it matter to you but ill answer your questions.
1. no im not.
2. no is not my intention to revive old thread but if there is a question i seem to have i will ask
3.for your knowledge that is how i found the thread using the search function.
thanks for asking
Old Jun 24, 2011 | 01:26 PM
GLE 63S
So just PM him instead of reviving an old thread!
