Evosport | New Lightweight 2-Piece Front & Rear Rotors for W211 E63 AMG
Old Apr 26, 2010 | 09:45 PM
Simon @ evosport's Avatar
PREMIER SPONSOR
Originally Posted by dsC32
How much do you charge for the rotors without the hats?
Rotors are $289/ea plus $85/ea for hardware.
Originally Posted by sack5000
Is that in any order so Akebono works as well as OEM? Thanks,
Akebono has less brake dust as its ceramic based. But I'm going to have to stand corrected here. Right now, we only have OE or Porterfield R4S pads for the E63. The Pagids and Akebono's are for the older 8-piston caliper (55 AMG) as of right now.
Old May 2, 2010 | 11:31 PM
dsC32's Avatar
'07 E63; 05 C55 gone; '02 C32 gone;1996 SL320;1978 280CE Gone
Simon, is the Pagid 2687, 8038, or 2488 a correct pad for the 2007 E63? It is the only configuration that appears close to the stock pad. The 2687 is 20mm thickness, 8038 is 22mm, and 2488 is 2mm (doubt this is right).
Old May 5, 2010 | 03:13 PM
citylightva's Avatar
2007 E63, 2005 Dodge Ram Hemi
And Carbotech....http://www.ctbrakes.com
Old May 8, 2010 | 05:26 PM
dsC32's Avatar
I checked with Carbotech. They do not have pads for the E63, but will make them up if we supply the backing plates. I will probably have some backing plates after this next weekend on track, and may try it.
Old May 11, 2010 | 02:46 PM
PREMIER SPONSOR
Evosport Titamium Brake Pad Shims
Whether you use backing plates or not, install our new Titanium Brake Shims (Ti-shims) to help mitigate heat transfer from the pad to the pistons and ultimately to the brake fluid to reduce fluid temps and brake fade.
Shims will be available very soon for the 63 AMG brakes:
Old May 11, 2010 | 03:07 PM
tylersphile's Avatar
2004 E55 AMG
Rebranded Girodiscs
These rotors look very similar to Girodisc rotors - rebrand perhaps?
Girodisc makes some of the best rotors around, they were heavily involved in the design of the Porsche GT3 braking system if I am not mistaken. Although Girodisc does not list available rotors for the W211 on their webpage - I do have a set on my car, and they are beautiful pieces of art and provide superb performance. However, it does appear that these Evosport Rotors are quite a bit less expensive than their Girodisc counterparts... so if they are rebranded, I'm wishing I would have purchased them from Evosport!
Is this the case Simon?
Quick and perhaps ignorant question - do the braking systems differ between the E55 and E63? I assume yes, as this thread is labeled for the E63...
