TB grind 74 to 80 Do it !!
Old Feb 25, 2010 | 04:41 AM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
Do this mod !! It is super damn easy--- for any TB.
less than 15min to get the TB off the car and start grinding the middle post that holds the blade.
I agree with the other tread and have little else to offer.
I cut out the middle portion of the bar on the top side, and left some of the post on the edges... I also grinded the back bar but not too much -- You need those threads for the screws. Also, grind the excess screws away.
No dyno and wont have any later -So, no concrete numbers for you guys- The streets are wet but I can feel a difference... Push and aggressiveness feels like I reset the ECU and driving on dry streets... but I did not reset the ECU and the streets are wet. So, I expect to feel more power when I have traction and the traction control is not interferring as much as with the damp roads. I can believe the ~20whp that is claimed.
Old Feb 25, 2010 | 09:07 AM
kjlindgr's Avatar
Viking War Ship
Pictures?
Old Feb 25, 2010 | 10:21 AM
mikeevo's Avatar
2005 Silver E55
I thought it was more like an hour job. and you have to crack open the supercharger to get it off. can you give details on how its done . I have done similar grinding jobs on other TBs but held up when i read you have to crack the case on the supercharger and then try and reseal. Pics would be nice.
thanks
Old Feb 25, 2010 | 10:43 AM
reitmeid's Avatar
2005 S55 1982 300dt
https://mbworld.org/forums/w211-amg/...rted-85mm.html
Old Feb 26, 2010 | 01:19 AM
only 4 star bolts hold the TB to the supercharger --- The black rubberish funnel that attaches to the other end of the TB is easy to remove. You just pop it off -- It has one tab on each side "2 total" -- After you take off the intake tubes -- you can take both airfilter boxes off at the same time.
It is simple - simple -- just start taking the stuff off - you will see it is brainless once you get started -- I was afraid too because I am not the best wrench turner. No problems at all.
Old Feb 26, 2010 | 04:01 AM
I dont know how to post pics on here -- i cant click and drag -
Old Feb 26, 2010 | 06:09 AM
ABALONE's Avatar
2001: Supercharged E55 AMG
Can't really see how this would translate to a 80mm from a 74mm in diameter? Any proven dyno results on this?
That would mean that a 82mm would be a 88mm Sounds a bit odd?
Old Feb 26, 2010 | 06:24 AM
Hammer Down's Avatar
2015 E63S, 2018 E63S
https://mbworld.org/forums/3825967-post1.html
Old Feb 27, 2010 | 03:13 AM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Didn't you have some pics here, gone???? Nice mod.
Old Feb 27, 2010 | 04:55 PM
i have some pics but i dont know how to paste them into the comment thread
Old Feb 27, 2010 | 06:23 PM
mikeevo's Avatar
2005 Silver E55
scroll a little further down under the message box and you will see tab that says manage attachments . click this , then a box that says brows and select the files off of your computer then click upload and your down.
Old Feb 28, 2010 | 12:31 AM
jimmysanjuan's Avatar
2023 GLE 53
Quick question. Do you remove the butterfly plate screww before you grind the shaft? Thanks.
Old Feb 28, 2010 | 04:05 AM
yes - take out the screws 1st -- then grind
Old Feb 28, 2010 | 04:26 AM
its not all polished up or a finished product but you can see. the back side has been flattened out and you can see the screws appear to be much longer now... You can see in the front -- i cut out the middle section and left the edges.
As stated this is not the finished job --- i polished the backside down a lot more -- and redid the edges on the front to look less shi77y
Attached Thumbnails TB grind 74 to 80   Do it !!-dsc05816.jpg   TB grind 74 to 80   Do it !!-dsc05818.jpg
Old Feb 28, 2010 | 10:38 AM
Hotrod-Realtor's Avatar
CTS-V 2013 Wagon
Wow, that looks like an aggressive grind to me.
Curious if there are any drivability issues or idle problems?
Thanks,
Warren
Old Feb 28, 2010 | 04:54 PM
no issues at all -- I did not bore out the diameter of the TB and i did not grind down the blade's diameter. Other members made the point that this will effect the idle -- So, i did not mess with that... I did taper the edge a bit... not too thin because i dont want it to break or bend.
The throttle is more responsive and my gas mileage has improved a little bit. Car is smoother and quicker.
Old Feb 28, 2010 | 05:30 PM
benz_addict's Avatar
V12TT
I want to attempt this as well. But... not trying to bust any ***** or anything your slide looks really rough with lots of deep scratches everywhere. This will not help airflow as it has to be smooth and slippery. Give it a nice metal polish to finish it off
Old Feb 28, 2010 | 05:52 PM
you are correct -- but like i said that is not the finished product that i put into my car... Good luck on your project - just do it -- you will only be sorry that you waited.
Old Feb 28, 2010 | 06:30 PM
V12TT
My bad.
I can't wait! Buying the grinding tools tomorrow
Old Feb 28, 2010 | 08:19 PM
Karlson's Avatar
06 E55
I can't wait for you guys to grind it to One Meter!
Old Feb 28, 2010 | 11:23 PM
you will really feel it when you get the pulley upgrade too --- its that whole 1+1 = 3 concept... As they work together they get more power than seperately
