Evosport | New Rear Stability Kit for W211 E-Class
One of the weak points in many of today's high performance Mercedes-Benz vehicles is the lack of, or extreme limitation in rear toe adjustment. This results in an undesired "toe out" condition when the rear of the vehicle is loaded up or on throttle. The effects are a very unstable or unplanted rear end with excessive over-steer that does not seem to want to grip. This is even more noticeable on modified vehicles where a lot of torque to the rear wheels is realized in low gears and in the low rev range. Since there is no practical toe adjustment in the factory suspension components, even the best alignment is unable to mitigate this issue.
The Evosport Rear Stability Kit (Adjustable Rear Toe Kit) is designed to address these issues. Installing the Rear Stability Kit will provide the ability to easily and properly adjust the rear toe during alignment to mitigate the "toe out" situation and provide added stability and safety to the vehicle. The chassis will feel much more planted and controllable, especially during heavy acceleration.
Kit includes left and right stability arms and mounting hardware.
Application: W211 E-Class (all), W219 CLS-Class (all), R230 SL-Class (all, except SL65 Black Series)
For more information, or to place an order, click HERE. Or you may contact one of our worldwide dealers using our Online Dealer Locator.
Kit Features:
- Lightweight adjustable arms
- High quality heim joint design for length adjustment
- Black powder-coated chromoly shaft provides high strength to weight ratio
- Jam nuts allows for easy lock/unlock of adjustment mechanism; relieves stress on shaft during adjustment
- Black anodized billet mounting bracket
Benefits:
- Easy to install and adjust
- Allows for precise and accurate adjustment of rear toe during alignment
- Provides stability and more control during acceleration and cornering at all speeds
- Added safety to reduce over-steer and increase rear control
- Decreases wear on rear tires by providing more rear end stability
- Improved performance during acceleration and cornering
Kit Features:
Benefits:
'06 E55 AMG Evosport project car. 2nd Owner
Hey Simon, do these come set to factory spec length ? And then can be adjusted during alignment. So that if they are on the vehicle before alignment it will not cause any undue effects.
Well, my question was answered when they arrived, NO they are not set. They are some very nice bits to be sure, however, I do wish they would have come with some installation instructions, ie.. torque specs for the mounting hardware etc...
Apologize, they should have been included in the box. I just emailed them to you.
E63 AMG
Any other mods you recommend.
Just bought an E63 and wanted to know what other suspension mods do you recommend as a bang for buck. Does the ride stay the same with your kit here or does it get harsher. Also what other mods really open up the car.
You can find our power mods for this vehicle by downloading our Vehicle Product Guide for the 63 AMG here:
http://www.evosport.com/product/vehi.../MBZ_63AMG.pdf
One of our clients just did an independent dyno test on our 63 Power Pulley here:
https://mbworld.org/forums/c63-amg-w...-2010-c63.html
Weight savings is negligible. I believe stock is right over 3 lbs and our is right under 3 lbs. Install is 2 hours. We recommend an alignment to set rear toe after that.
E63 AMG
Good looking pieces though. What other components would you change to tighen up cornering but NOT AFFECT ride quality. The E63 really has MOOSHY steering feel. Any mods for this problem????
Got the pieces in, while not a major PITA to put in, they were a challenge with the exhaust somewhat in the way(at least for me).
They look really good, and, what I really liked was the reaction of my alignment guy. Jeff @ http://www.stokestirepros.com/ . He really thought they were sweet and is going to recommend them to some of his clients.(I pointed him to the webpage Simon )
Still haven't driven on them much so I can't post a review just yet.
