Halogen or Xenons?
Old Apr 7, 2010 | 01:29 AM
BelaMeca's Avatar
From: Los Angeles,Belgrade.Current Residence Zurich.
2017 Mercedes Benz E220D/GONE!JUNK!Current GLC Coupe 350d 4 Matic
Halogen or Xenons?
I really can not tell what i have?
Can someone tell me how to find out?
Old Apr 7, 2010 | 01:42 AM
jpohl402's Avatar
E55 then E63, now back to an E55
Halogen are old style yellowish.... (think 1980s cars here)
Xenon are newer (like 2000 up) Acura - BMW - etc
Appear much brighter - typically like a bluish or mostly white.
Stand outside the car in dark. Pretty easy to notice.....
Old Apr 7, 2010 | 05:45 AM
tscales's Avatar
2005 E55 Wagon, 2017 C63S Cab, 1986 560SL
Do they dip? The Xenons do a quick dip towards the ground and then back up when you turn them on.
Old Apr 7, 2010 | 08:55 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Colored bulbs can and will fool
Preferred way to tell is to pull a bulb. Does it have a filament or not?
Old Apr 7, 2010 | 11:22 AM
Busta Riles's Avatar
1969 280S, 1991 300E
In Canada,
If the car has headlight washers, it has bi-xenons. No exceptions.
Look for washers.
Old Apr 7, 2010 | 11:44 AM
TheVazha's Avatar
W213 E63
Not necessarily true. Mercedes discontinued xenon lights in 06-07. The lights you see now are high efficiency halogens. HID's (aka xenon) were an option in 04 and 05.
If you cant tell by looking at them just pop open the hood and there should be red sticker warning you of high intensity shock from the High Intensity Discharge or "xenons"...
I have xenons and at night they look nice but for example, a new lexo can pull up next to me and completely engulf my lights and outshine me. And then you know what happens
Old Apr 7, 2010 | 11:55 AM
cal1's Avatar
SL55, ML500 & Acura TL
Yep, he has a well illuminated view of an a$$ walking.
Old Apr 7, 2010 | 12:06 PM
TheVazha's Avatar
W213 E63
El Ohh Ell
Old Apr 7, 2010 | 12:12 PM
J 2OOI's Avatar
2012 JDM
This is incorrect. Xenon's are still an option on Mercedes cars to this day.
Old Apr 7, 2010 | 12:42 PM
TheVazha's Avatar
W213 E63
I stand corrected.
Old Apr 7, 2010 | 12:55 PM
JonMBZ's Avatar
06 C55, 09 E350
I agree with the head light washers, also you can run your vin in the EPC parts catalog and look at the datacard. http://epc.startekinfo.com/epc/
Old Apr 7, 2010 | 03:14 PM
TopEndS62's Avatar
2005 BLK/BLK E-Double Nickel.
+1 just pull the bulb out
Old Apr 7, 2010 | 03:42 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Don't. I've seen cars with headlight washers and no BIX. Was listed on the sticker as a separate line item.
Old Apr 8, 2010 | 01:05 PM
anwar_m14's Avatar
2003 E320 Pewter KG
does the light build up when u turn it on? xenons start with a pale illumination then in few seconds boost up to its normal level
