Looking for johnson pump cm 90 / required urgently!
K3 05 E55 sold, 09 GL550
Yes you can . I bought 2 from them . one C090 pump and a CM90 pump . if eurocharged had these that is great.
Former Vendor of MBWorld
How loud is the CM90? Only reason I ask is.. I ran a Jabsco "Water Puppy" in the C55. That pump was nothing short of awesome... That pump stated running as soon as the engine started and never stopped until i shut it off. So for like a year and half it ran all the time. No issues at all. However its was loud, You would know if it wans't working. I want something less loud this go around.
I was leaning in the direction of running 2 Mercedes pumps (sorry about the slight thread jack)
I was leaning in the direction of running 2 Mercedes pumps (sorry about the slight thread jack)![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Really? Cool. How did you order them? I had to order through a distributor/retailer aka West Marine
What is your definition of loud? You can't hear it from in the car. You cant hear it over my exhaust at idle. I don't consider it loud and it flows like a champ. Mine is setup for continous running too, so soon as I click the key over 2 it turns on and doesnt stop til I turn it off. Recently put in a ice resevoir with 1" lines going to and from it. It shoots out like a jacuzzi jet!![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Than that's the pump for me, My old pump was loud, You could hear it in the car when it was in the AUX position. It sounded like an 50cc mini bike. I lady would always say "that's obnoxious" I would just tell here, she doesn't understand.
Mercedes Benz E55 AMG
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
1st.. Wats the difference between stock and this johnson pump (CM30 and the CM90) which one is better. does it stop the car from over heating
2nd... what about the inter cooler should that also be changed to PLM heat exchanger.. i need a total re-upgrade from A-Z
My problems are:
A/C compressor
New Pump
New inter Cooler
and the famous supercharger "CHIRP"
![Cheers](https://mbworld.org/forums/images/smilies/cheers.gif)
1 Post
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
/\ Well the CM90 pump flows alot more then the CM30 pump. But i read that some people think it may flow too much which might not aid in cooling as much as the smaller one and might cause cavitation. I decided to do the CM30 pump after reading the threads on different pumps. Good luck.
Aaron
Aaron
