DIY hidden charger
DIY hidden charger
I had my phone charger in the rear socket for a while, but its a bit annoying and I didnt like the way it looked down there.
If you get the floor panel out of the compartment between the seats, you will see a brown and yellow/black wire, those run to that rear socket. I disconnected their harness to avoid accidentally frying the fuse, and attached these:
Oops, should've gotten different colors, oh well. I just checked continuity lots of times to make sure nothing got mixed up. On the other end, I hacked a 12V socket from a splitter and prepared it to get attached:
The socket, harness, and charger are now connected and tucked down:
Plastic floor is down, now the USB charger and iPod cables are coming through:
Looks cleaner:
Looks cleaner:
Haha, I have wanted to do something like this for a while. Except I wanted to flush mount a USB port to the inside of the console. Well done sir!
There are 2 small openings on it, on the sides towards the front. Get a tool down through the opening and press to the side while pulling it up through the round opening. That will release the clips and it will pop up.
