Comand Unit / MP3 Playback Issues..... Please Advise
Old May 22, 2010 | 07:33 PM
jpohl402's Avatar
E55 then E63, now back to an E55
Hello,
I have been using - same media (memorex cd-r) - same burning drive, & same software program... computer is only a few months old, no issues with discs ever.
Recently started having problems w playback of mp3 cds in single slot Comand drive. Now I cannot recall if these same discs have played perfectly in the past, or if I had never fully listened to them (and therefore never realized the problem.)
I tried the problematic disc in both 05 e55 and 07 e63. Result was very similar on same tracks.
On 55 - the track starts to play, but only gets to one second. It then resets back to 0 and stays frozen there.
On 63 - after about 3-4 seconds of non-playing, the cd gets ejected/spit out immediately. I initially thought it was a problem w e55's older command and MP3 compatibility issues - but that is not the case.
Thoughts? As this is frustrating..
Old May 22, 2010 | 07:51 PM
Timeless's Avatar
2005 E55 ///AMG
I had issues with this also that never really got resolved fully as I started using my IPOD full time...however I believe it might be the physical CD/DVD burner I am using...never got a chance to try again with a different one.
I can tell you my dealership replaced the entire command unit and 6 disc changer and that made no difference.
Old May 23, 2010 | 03:25 AM
cahiil55k's Avatar
I used to have similar problems but not on the Benz. Usually it would be that a CD would play in the car but not on home stereo. Try burning onto a different brand of CDs or set the burner to a slower rate for one burn session.
Old May 24, 2010 | 01:08 AM
jpohl402's Avatar
OK thanks guys
Old May 24, 2010 | 11:35 AM
jpohl402's Avatar
I lowered my recording speed...
appears to have done the trick
Old May 24, 2010 | 11:42 AM
Sathinas's Avatar
S65
I don't know which Comand version you have, but I've always had a lot of issues with playing back MP3's until I tried an experiment once.
I removed ALL MP3 ID tag information out of the mp3 files. Burned the CD (even DVD) in ISO 9660-1 UDF 1.02 Format
MP3 CD's and DVD's load and play nicely now.
Also, make sure your tree folders aren't deeper than 256.
Old May 24, 2010 | 11:43 AM
pullejo's Avatar
'12 E63, E55(sold), C32 (sold), '65 Skylark GS 445 convertible, '12 ML350
What did you bring it down to? 12x?
Mine does the same thing - it will play a few tracks...then every once in a while gets to a track and goes... *pffft*...and spits it out as if it's sick of having a disc of all of Metallica's good albums in it.
Old May 26, 2010 | 02:21 AM
jpohl402's Avatar
Was at either 40 or 48x.
Did 24 now. Have literally skipped through every track on new CDs and they all play fine....
