E55 82MM TB Install DYI! and some other goodies.
HAHAHA!Thanks to Shardul and Scott (AUS-E55) and KuaveSTi (my Cousin), and thanks to Brooke (Exotic-Metal) for the powder Coated surge tanks!
It was previously modified by Exotic-Metal. On my car we had to pull the clips off of the intake to push it back in order for the CF to fit. Notice the front Carbon Fiber cover doesn't properly sit.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Y'all do realize that the TB and Snout are AMG Factory parts?
To the OP, which wires did you have to switch? Thanks in advance.
i want to ask you about the small filter. what it is for ?
i noticed there is a difference in the S/C inlet between my stock and the 78/80 OEM, i don't have the seconed hole in the 9th picture, the stock one had two, but the 78/80 doesn't has it (where your stock has the black rubber with red inside), so i don't know where to put the black pipe that is comming from both sides into it.
what its job ? is it harm just to keep it there not pluged ?
My 82mm TB has an AMG Sticker and Part number, same for my Supercharger snout.
any Benz if it is still , thr RPM doesn't pass 3000.
but about the Thermal spacers, they guys can aswers you because i didn't used it and will not.
So i guess its safe to say yes, you can use the old one. Although we did change the gaskets under the SC and from the Surge tanks to the SC.
