Another 82mm t/b install
Old Jun 6, 2010 | 04:36 PM
lowprofile's Avatar
E55
This was just covered so rather than making another diy, I'm just showing a different outcome.
Here, the factory PCV in intact and functional. Because there is no adapter plate, the airboxes align properly.
It took the ECU two days of light driving to adapt to the new t/b. You can see the LT fuel trims are within reason. BTW, I did the "Sneaky ECU reset" after the install but that didn't make a difference for me. If I was to do it again, I would have disconnected the battery before starting the r&r.
So far so good, no CEL. I'm showing 2.0% or 2.4% throttle position when fully warmed up.
Old Jun 6, 2010 | 04:41 PM
TTMotorsports's Avatar
Former Vendor of MBWorld
Whatever we're tuning!
Awesome job BK!
Let the modding begin!
Old Jun 6, 2010 | 04:51 PM
lowprofile's Avatar
E55
Thanks BB, means a lot coming from you! I know how fastidious you are.
I'm coming to you when you are setup for tuning!!!
Old Jun 6, 2010 | 05:26 PM
kjlindgr's Avatar
Viking War Ship
Can you post up the part number of the factory Y-pipe that mates to this throttle body?
Old Jun 6, 2010 | 06:06 PM
blackbenzz's Avatar
haters crazy
The 82mm TB just bolted to the 80mm inlet? Looks really clean
Old Jun 6, 2010 | 06:34 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
When having my car dyno tuned we really were surprised how restrictive the stock air boxes really are. When possible really open her up and snag a VRP airbox. She'll thank you for it!
Really nice install!
Old Jun 6, 2010 | 06:46 PM
KLR CLS's Avatar
CLS63 PP
2nd'ed..Did the 82mm just bolt to the 80mm OEM snout?
Old Jun 6, 2010 | 06:47 PM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Very nice job. Clean.
Old Jun 6, 2010 | 07:03 PM
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
wow .. we have a new mistery here
a clever welder can easily move the 2 bolting "ears" on the back of the TB to fit the inlet, or weld 2 new ears on the inlet ...
Old Jun 6, 2010 | 07:17 PM
Old Jun 6, 2010 | 08:53 PM
lowprofile's Avatar
E55
I'm out right now, but I will post a pic or two of the t/b mount when I get home.
Old Jun 7, 2010 | 12:50 AM
lowprofile's Avatar
E55
The y-pipe that I used is the 80mm version. All you need to do to make it work on the MB 82mm t/b is replace the factory seal with a set of 2 o-rings. I posted the part # in this thread: https://mbworld.org/forums/w211-amg/...ment-help.html
Old Jun 7, 2010 | 01:11 AM
lowprofile's Avatar
E55
Thanks Ahmad. You were one of the first to do this mod on your own, and I owe you for providing the part #'s.
The upper bolt holes on the t/b only differ ~ 2mm from the 80mm inlet. I slightly elongated the holes in the t/b and the gasket to properly align them. For the bottom I had to add some metal to each side and one of the bolt holes needed to be filled because it was too close to the new thread location. This was the first prototype (in other words there is room for improvement). I didn't add as much material on the bottom right corner as I would have liked to.
One other thing, I had to machine a small channel at the top of the flange to clear part of the t/b.
Old Jun 7, 2010 | 01:23 AM
lowprofile's Avatar
E55
Thanks for the heads up. I'm going to keep following the tracks which you and some of the other OG members layed down for us.
Old Jun 7, 2010 | 09:41 AM
blackbenzz's Avatar
haters crazy
Nice work! Are you going to port match the inlet to the TB as well? Oh and you are welcome for the p/n's. I love helping fellow enthusiasts go faster without getting raped!
Old Jun 7, 2010 | 10:37 AM
skratch77's Avatar
2005 E55
Nice work man,I havnt givin up on my tb horror yet.Is that a mb throttle body?or the porsche one?
I think all my problems were from not having a mb tb and just throwing a e55 tps sensor on a different tb.If you are seeing 2.0-2.4 fully warmed up and in drive at a stop light youre good to good bro.
Old Jun 7, 2010 | 10:46 AM
Angelo I think you know your REAL problem and it has NOTHING to do with the brand of TB but the kit!
Chasing the TB fix for almost a year!
Nothing like *****ty customer service!
Old Jun 7, 2010 | 09:58 PM
lowprofile's Avatar
E55
Yes, the inlet was port matched. The gasket is bigger than 82mm. Just added that pic so you could see that the t/b was centered on the inlet.
Angelo, yes it is a MB t/b. You could always eliminate the PCV to bump up your throttle %. Would not be my first choice but it would basically be getting rid of a vacuum leak.
Old Jun 7, 2010 | 09:59 PM
lowprofile's Avatar
E55
Double post
Old Jun 7, 2010 | 10:22 PM
KLR CLS's Avatar
CLS63 PP
What is the cost of the 80mm AMG housing?
Old Jun 7, 2010 | 11:23 PM
BenzoBoi's Avatar
Super Moderator
W221
Very nice!
Old Jun 8, 2010 | 11:59 PM
lowprofile's Avatar
E55
Thanks Sun!
Here are the part#'s for those interested;
-MB 82mm t/b: 2731410325
-82mm t/b gasket: 2731410680
-80mm s/c inlet: 1131400912
-s/c inlet gasket: 1131410780
-80mm Y-pipe: 1130900329
-O-rings for Y-pipe: 90025K396 (mcmaster.com)
-s/c to head intake gasket: 1131410980
-you will also need gaskets for the surge tanks, not sure what that part# was.
G/L
Old Sep 20, 2010 | 03:15 PM
Forrest Gump 9's Avatar
shrimp boat
Wow, this is how 82mm tb kit supposed to be. Very nice and clean. Big thumbs up for OEM look.
Old Sep 20, 2010 | 04:24 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
around $438
chawkins2001's Avatar
2006 E55 AMG
very nice. did you feel any significant power gain from the install?
