A/C Recharging
Thanks!
Perhaps add a tiny bit of freon and then see if that improves the system somewhat. If not STOP and go to dealer.
They have a machine that adds the factory amount of freon you need and removes any extra that could be slowing down the system.
You overcharge it and you are looking at major problems with these $$$$ systems.
Worst part about our systems is that the compressor CONSTANTLY runs on these cars. It's spins up and down like a turbo depending on need. No old time clutch system..... so it's hard to put gauges on the thing and judge freon from them like in the old days.
You could have well under the recommended amount and gauges show you are 100% fine while the compressor is spinning like a jet engine to keep up.
Add a tiny bit and then run it to stealer and have them top it off. Better safe than sorry with these cars.
Good advise, I just did AC service which add freon I guess.... I paid $120 and now its really cold. I just want to play safe with these cars...
Common symptoms of low freon are drivers side being warmer than passenger. Having that?
Sorry to spook you on adding freon. Many guys have added part of a can and drove away happy and ice cold.
Just that you could have clogged expansion valve, evaporator, a bad sensor, or a few other things and throwing freon at it would end up damaging the system when you overcharge.
