Seriously Negative Camber Issue After Brake Job
Relatively recently, I had a new set of brakes installed. After a few K miles, I noticed that my left rear tire was showing some strips of white on the inner edge. I took a closer look and noticed that just that one wheel has visibly negative camber, which obviously caused the dramaticly uneven wear. I have been too busy to take it back to get it fixed and am not sure when I will be able to, so I drove it a little longer to get a little more life out of the tire. When I finally took it off to put a stocker back on, I noticed that a bunch of the steel belting was poking out! Luckily it didn't blow out on me, but I was wondering how and why the tech could've messed up the camber so bad on just that one wheel to do a brake job. They said they'd do a free alignment for me but couldn't replace the $500 tire. Honestly, I don't know if I can trust them to fix it right or whether an alignment is what needs to be done to fix the camber. Problem is, the stock I put back on isn't going to last much longer either, and I don't want to ruin another tire w/ good life left on it. Since my front tire went flat today, I've decided to put all my stockers back on all corners, so I was wondering if there is any way that I could try to fix the camber on my own while I'm changing the other three wheels/tires anyway. Forgive my lack of knowledge, but I'm not much of a mechanical DIYer. I got a new baby now (big reason I've had no time, along w/ running my own biz), and I want to get it to drive the way it's supposed to, primarily for his safety. It's bad enough I have to ride w/o my HREs, so the last thing I need is a blowout next time. Any advice would be greatly appreciated!
