Trunk tank installed and my thoughts.
If you buy hose, get 40 ft of it.. Some have posted 25 but not near enough..Found that out the hard way..My bad!~ Thanks to Shardul, for the tip to run the hoses over the inner fender liner, that helped! Between jacking the car up and couple trips to the store, 10 hours is about the time.. The other tough area , is getting those routed through the rear diff. area. Only clean way, is to basically follow the exhaust. Half shaft is close to hoses and so is the hot exhaust.
My system held 5.5 gallons , with the 38 ft of hose used (3 ounces per foot of hose) and water in the tank. BTW, anyone have a good tip on how much water to keep in tank , for day to day driving? I filled to within one inch but water expanded and overflowed in the trunk..
I am running a Meziere pump up front and using a 1200 GPH bilge in my tank to power feed the front pump.. As you can see in the video (before air was bleed) that it is flowing like a Russian race horse..
Test, 91-93 ambient and heat soaked engine.. Cruise IAT were 14-17 deg and on a run from 30 mph to 105, only hit 147 deg. Recovery to 15 deg over ambient , happened in about 8-15 seconds..
My estimate on having the extra 5 gallons, is worth 5 deg better cruise temp and 20 degrees peak.. Now add ice, and things will get fun..
CLICK on picture to see video..
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
It took my tech few days but they only charged me 5hrs labor. I can't for the life of me figure how you used near 40' of hose?? We used half that, maybe 25' tops... Def NOT easy to install, as you learned the hard way don't fill to top, leave few inches empty @ ALL times.
I bought 30 feet of hose first and my bad for not doing an exact measure.. Laid a tape by the car and 30ft looked to be ok but then came up short..I then went to another autoparts and bought 40 ft and that was about 2 ft left to spare.. I gues the CL is a lot longer than the SL, as I ran the lines in a very striaght line, excpet going over the fender.. Either that, or these redneck`s down here cant measure heater hose when they cut it..
They got all wild, when I asked for 40ft, like that was a big choir to manage..lolYou state that the tank should be a few inches from empty at all times ? Don`t you mean a few inches from full?
www.ultimatepd.com
Is this a custom fabricated tank? It looks perfect for this chassis. Great Job!!
AHH Sig indicated Garrett HE.. NM
(+1 on parts guys acting like I ordered a ***** to custom fit cordless drill or something bizarre
when asking for 20'-25' Goodyear heater hose
Sean, thanks! I used 90 deg brass fittings, so the lines would have room to go between tank and wheel. I have 1/2" room to spare. Did push tank closer to drivers side in wheel, to give the 2.5" clearance..
Here is a pic , showing the 90 deg. fittings and how they route to one spot (space between rim)
www.ultimatepd.com
Custom Headers, custom mid pipes, I/C tanks, fuel pumps and other mods just take a certian ownership quality to get right.. Oh yeah, I used a fitting called a Riv-Nut to fasten the tank down into the trunk. You drill a hole and then use a tool to compress a brass nut ino the trunk.. This gives a nice , clean and strong threaded fitting to bolt too.. Then just lay the carpet mat over the tank and forget about..
Unless you want to keep your coffee thermos hot , then drop it in the tank and you will be set..
www.ultimatepd.com
Two more little facts. 1foot of heater hose holds 3 ounces of water, so add another 1.5 ish gallons to your tank size.. Second, average gates heater hose weighs .25lbs per foot. Average tank, pumps, water and fittings will add 50-60 lbs to the car..
www.ultimatepd.com
