Exhaust leak... why do you lose power?
).The part of the explanation that doesn't make sense to me is how the O2 sensor would read too much oxygen, as the system should be under positive pressure, which should prevent the intake of any outside air through the leak (at least that is how I'm reading it). Any further explanation would be appreciated.
The funny thing about the accident was, that out of over $8,000 in damage, nearly $5,000 was for factory exhaust parts.
Thanks, that makes complete sense.
if you have a leak before the 02s you will lose exh there and the 02s wont read it and add fuel because it thinks the car is running leaner than it is.
Redline,we have a huge 5.5 v8 with a blower slamming boost down its throat,I cant see how air could ever get sucked in at the headers or anywhere in the system with all that flow coming out.
its not running lean because fresh air is hitting the o2s,its running lean because unmetered air is flying out the leak!
