CEL gone suddenlly "orginally caused by remving Cat"
That CEL was on because I installed Kleemann headers and the primary cat had to be removed, and every time this fault is erased, it comes again after 300 km or so of driving.
I am not sure what caused to disappear but after driving 300 km, I will see if it will show up again or not.
Is it possible that the car programmed itself to the new set up? I don't know, it could be !!!!!
We do have cats that mate up to the headers and the rest of the exhaust with that setup you will not get a cell. Its important to check with your State on whats legal and whats not. However, what you do or how you use them is 100% up to you.
This is becoming very hard to word the appropriate way..
There are a lot of people who use their car for off road use, and have their tuner shut that CEL code off.
PM me.
The dreaded "cat efficiency code"(the cat delete code) or any related code that is triggered with a cat removal is a direct correlation between the primary and secondary O2 sensors reading the same air instead of air that has passed through a cat. The extensions will have the secondary O2's reading a different volume of air since they sit out of the direct exhaust stream.
PM me if anyone needs these extension bungs.
