Urgent notice. 03-06 E55's that were involved in the fuel sender recall are bombs.
Rating: Thread Rating: 9 votes, 5.00 average.
Old Jul 24, 2011 | 05:28 PM
  #276
SPVFD47's Avatar
04 E55 - 97 E320 - 85 300D
Well I got the chance to take the seat out and take the inspection covers off today. I didn't notice anything but the car was at a quarter of a take. I went and filled it up and here is what I found after driving 10 miles.
If you look to the upper right you can see where the black plastic (which I'm guessing is part of the tank ) is getting wet with fuel. You can also see where the fuel is sitting in the base of the unit to the inside on the right side, which is the low part of the unit due to the way it sits.
Camera angled back to get a better view of the tank.
View of the pool of gas on unit on the rear side. It looks like its leaking from that plastic piece on the left side of the photo which I'm guessing is the sending unit. This could be the cause of the whole problem. Hard to tell if its 2 pieces or not but it looks like theres a seal there.
Just another shot of the above with better lighting.
Now until today I never smelt gas on the inside of the cab. I'm hoping it's only due to the fact the covers where off. I have smelt it on the outside after filling up. I also noticed that while driving and moving air was coming thru the inspection holes while moving. So if a sufficent amount of fuel leaked there is the possibility of the fuel running down the tank to where ever.
I had the SBC Pump replaced on 28 June and mentioned to the SA that I smelt fuel after filling it up. I have the print of the leak test which says it passed. Guess I'll have to show him the photos.
Old Jul 25, 2011 | 11:26 AM
  #277
tpick23's Avatar
E63
UPDATE- Fuel Sending Unit
I took the car to the dealer and had it looked out, got good info to post up.
They diagnosed fuel sending unit and will be replacing it and the fuel pump at no charge (whew!) Parts alone are $1100 and with labor would be over $1500.
The tech and service manager say that if it is the unit then gas will be on top of it as many pictures in other posts clearly show. The car will smell of gas after filling up. If the problem is the evaporator hose issue then the car will throw CEL code and smell like gas. They had a few tanks to be discarded and I got a couple pictures.
First pic shows the hole where the sending unit goes and where the seal to the evaporator hole connects. It is the white(ish) nozzle to the right of the unit hole. Remember the unit is under the drivers side and the pump is under the passenger side.
The next picture is the seal that leaks if your problem is the evaporator hose connection. This thing would be under the middle of the rear seat and can not be seen directly with the eye. Apparently techs use a light and mirror to see the seal and along with whether the car is throwing codes, diagnose the issue. If this seal is bad then the tank has to be replaced.
They say that since the tank is under pressure that if its the seal leak it will loose fuel pressure and throw the CEL code. Of course a car could have both problems at the same time but they seem to put a lot of emphasis on the codes or not. The sending unit in my car had fuel on the top and around where it fits into the tank so I thought I may have had both issues, tech said probably not. I never saw him use a mirror and I looked under the cover before taking it in so I'm not quite sure how they use a mirror and light but whatever. The codes or no codes makes sense.
Also talked about if this issue is due to ethanol, probably so but do not use any additive like is used in marine application.
Apparently the design of the fuel sending unit has been updated too. I will take a picture of it after its fixed.
Originally Posted by tpick23
Add me to the list.....same description as others but this is 2007 E63. 48,000 miles. Will take it next week for official diagnosis but it wreaks of fuel after fill up and goes away when the level comes down. I took the driver side cover off and found fuel.
Is the 2007 fuel sending unit the same part as the 03-06 units?
Attached Thumbnails Urgent notice.  03-06 E55's that were involved in the fuel sender recall are bombs.-fuel-sending2.jpg   Urgent notice.  03-06 E55's that were involved in the fuel sender recall are bombs.-fuel-sending1.jpg
Old Jul 26, 2011 | 12:25 AM
  #278
03RSTT's Avatar
13 E63
IMHO the tank will leak again. It may take 6 months...it may take 12 months but it will leak again.
The only real fix is to replace everything...tank, senders, fill tube and all hardware.
I went thru 5 sending units and even more seals in 3 years before MB finally replaced everything. Been fine since.
If you have any info on updated sending units please post the source. Is the pn different? What build date is updated?
I do not see how a vapor pressure leak inside the tank would change the fuel pressure at all. The fuel pumps and regulator are sealed and the bypass just dumps into the tank.
What an awesome thread. 12 pages and over 14,000 page views. Nice job MB.
Old Jul 26, 2011 | 08:22 AM
  #279
novae500's Avatar
W211
211-470-51-94 sending unit DS
211-771-05-79 same # for seal.
Had this replaced back in march 2011.
Old Jul 26, 2011 | 09:13 AM
  #280
tpick23's Avatar
E63
It sucks that this is even happening and for so many years now is rediculous.
Was your car giving codes?
Old Jul 26, 2011 | 09:45 AM
  #281
novae500's Avatar
W211
no codes, just gas vapors every time i filled up. Would last until a 1/4 tank went down and fumes went away. It started happening when i had an 9month old in the back seat and didnt want him to breathe it in.
Old Jul 26, 2011 | 10:00 AM
  #282
tpick23's Avatar
E63
Thats very similar to mine. Our girl just turned one on the 23rd.
Have you had trouble with it since then?
Old Jul 26, 2011 | 02:44 PM
  #283
novae500's Avatar
W211
Since the repair, no issues so far.
Old Jul 26, 2011 | 10:31 PM
  #284
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
This seems to be the "real" fix (and as I mentioned in a previous post here.) I was in today to see my dealer for some unrelated service and had a quick chat about the issue. The initial "fixes" were not solving anything (as you well know) but a tank replacement along with everything else is doing the trick. One reason why dealers hesitate doing the tank is because of the labor involved (sub frame drop.) And getting the labor charge rebated from MBUSA isn't as easy as they'd like. So a lot will depend on one's relationship with their dealer. btw, he said the parts aren't new but have been "adapted" for the issue (whatever that really means.)
What's unusual is that not all cars will develop the issue. They've seen W211s with high mileage and no problems, and the population with issues is relatively small compared to all registered W211s on the road. It's almost like luck of the draw.
But here's a good one: my dealership said they just did a fuel sending unit fix on a leaking car the other day...... the car: a W212.
Old Jul 27, 2011 | 08:54 AM
  #285
tpick23's Avatar
E63
You have got to be kidding- a new model same issue
Now that you mention "adapter," I remember that is exactly what my tech said about the new unit.
The service manager mentioned that there is a high cost of disposing the tanks too. They cant just throw them in the dumpster, some one has to come by and pick them up for disposal. The pictures that I got were from 2 that were lying outside for 6 months he said.
Anyway, I am dropping the car tomorrow morning for replacement so I will update as we go
Old Jul 27, 2011 | 01:04 PM
  #286
dgkalis's Avatar
g55
What if you just don't fill the tank all the way up?? That should alleviate the majority of the problem.... right?
Old Jul 29, 2011 | 09:51 PM
  #287
Newzchspy's Avatar
PLAID
You mean treat the symptom , NOT the cause. Makes no sense to me
I guess you could do that pending repair, BUT I would certainly hope that IF you had the problem, you'd get it fixed.
Anyone know the cost if MB does not step up and pay the parts and/or labor?? I've seen $3000 plus??
Old Jul 29, 2011 | 11:55 PM
  #288
bananacrrazy's Avatar
bmw 7 series
yup i have heard this, i think mb usa not taking this seriously
Old Jul 30, 2011 | 12:01 PM
  #289
SPVFD47's Avatar
I talked to a tech that I know. He works for the dealer that did the sending unit campaign on my 04 E55. He's going to talk to his service manager about replacing whatever needs to be done on my vehicle since they preformed the work and he knows that I take good care of the car. He would hate to see it burn up.
Old Jul 30, 2011 | 03:17 PM
  #290
Kflip2212's Avatar
2005 E55 AMG
same thing just happened to me yesterday i got the smell.. i checked under the inspection cover to find a pool of gas. i was driving on the highway right after i filled up only to about a quarter tank. mercedes says they wont fix it. i dont know if i was part of the recall in 2008 because i just bought the car last year. but it is listed under the hood on the recall campaign sticker. im pissed. any suggestions as to what i should replace??
Old Aug 1, 2011 | 12:30 PM
  #291
tpick23's Avatar
E63
UPDATE-
The car is fixed and no gas smell. They even left a full tank of gas in it. Here are the part numbers.
211-470-36-94 Auxiliary PU I guess this is the fuel pump
211-470-38-94 Sender Unit
211-471-05-79 Seal ring (x2)
Thats a different number than you have for the sender unit.
Old Aug 1, 2011 | 04:34 PM
  #292
moosejaw's Avatar
none
How much $$$$ did this come out to?
Old Aug 2, 2011 | 08:38 AM
  #293
tpick23's Avatar
E63
$$$$ = none
The dealer covered it for me.
I used the information from this forum to talk to the service manager. I took the approach of that I knew they could not just fix stuff without going through proper channels. I relayed to them that I knew there was a recall on the sending units for earlier model years and that my car seemed like it was doing the same thing. I took it to them for verification, the tech opened the cover and saw fuel, no CEL codes and supposedly checked the seal at the evaporator inlet. SM agreed to replace fuel pump and sending unit on the spot. They had to order parts, offered me a loaner which I declined and took the car home to sit in my garage until parts came in. I took it back, got the loaner for the day and picked up my car after work.
And to boot, they even had a full tank of gas in for me.
Attached Thumbnails Urgent notice.  03-06 E55's that were involved in the fuel sender recall are bombs.-sending-unit-invoice.jpg
Old Aug 8, 2011 | 02:41 PM
  #294
tpick23's Avatar
E63
And the story goes on....
Well, new fuel sending unit in place but the fuel gauge was not reading properly. I put a few hundred miles on it and noticed the gauge still over 3/4 tank. Filled it and it took 10.25 gallons.
Back to the dealer today, said the unit was bad and replaced it again, and I got another full tank of gas
This is crazy
Old Aug 16, 2011 | 10:14 PM
  #295
BoZo.E55's Avatar
E55
2005 E55 - Stock, 55k Miles
Hopefully I can get some help.....
Recap of what's been done so far (see below)... As well, the dealer is now stumped. The only thing they can come up with is the type of fuel I use (Costco) may have additives that are causing excess pressure to build in conjunction with the Arizona heat???? MB noted to use Shell and or Chevron. Just filled up with Chevron, I'll see how this goes. Any HELP would be greatly appricated!!!
What's been done so far:
- Pressure test tank, both via Star and smoke test (both negative)
- Both fuel pumps are great, no leaks or signs of leaking
- New charcoal canister via MB dealer (free as this was not the problem), canister was "soaked" with fuel per tech.
- Smell comes when tank is any any level, but when it's hot outside and lots of stop and go driving.
- Smell comes from passenger side wheel well and in the cabin
- No puddles or any sign of fuel anywhere only the smell of it
Old Aug 16, 2011 | 10:59 PM
  #296
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Never top off a Mercedes, if your canister was soaked you are over filling the tank. Your canister is most likely soaked again and as the tank heats durring the day and the air in the tank expands, it vents through the gas "soaked" canister producing the smell.
When fueling, stop when it clicks off the first time, do not put any more fuel in. This is very very common and yes the canister is in the pass wheel well.
I am surprised the dealer did not tell you how canisters become soaked, speaks volumes as to their lack of expertise.
Old Aug 17, 2011 | 12:17 PM
  #297
BoZo.E55's Avatar
E55
Agreed. I've never topped off. That's the strange thing, the smell happens at all levels i.e. full or 1/4 tank. As well,it could smell after a fuel fill up or a week later. The only common piece is the outside temp being hot.
Old Oct 10, 2011 | 09:59 AM
  #298
aghakauve's Avatar
GLC63s, W222 S63, W223 S580
I have the same exact issue. Leaking from the little plastic part of the unit.. I just ordered a new unit.
Urgent notice.  03-06 E55's that were involved in the fuel sender recall are bombs.-img_18333.jpg
Old Oct 19, 2011 | 02:32 PM
  #299
novae500's Avatar
W211
How funny that on the main page of the forum, you have the recall for diesels where the fuel filter is failing and causing leaks. But wont acknowledge this on the W211 where its happening as well.
Old Oct 19, 2011 | 05:24 PM
  #300
moosejaw's Avatar
none
What year cars or how old are they?
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
