Urgent notice. 03-06 E55's that were involved in the fuel sender recall are bombs.
I had this issue with mine and thanks to my extended warranty the dealer replaced the entire gas tank and the drivers side (which was leaking) fuel sending unit.
My co-pay/dectuable was $75.
Dodged a bullet there!
Alex
I too have the gas flooded driver side unit. The passenger side seems un-affected.
Wonder if we can light a fire under the right EPA *** about all this fuel evaporating into the atmosphere and killing all the poor trees or whatever gets those nutjobs riled up.
I did submit a complaint with the NHTSA as well.
__________________
2004 E500 w/ 120k miles, daily beater. Filled up last night, and my garage had a very strong fuel odor this morning. So much so, that I pulled it outside and was afraid to drive it today. I'll pull the rear seat when I get a chance and see what's what. Times like this I'm very happy to have options in the driveway....
I purchased a new to me E55 on Tuesday this week, last night I filled it with gas, later that evening I got an extremely strong smell of gas from rear drivers side wheel arch. I arrived home, checked online and discovered this thread.
That evening I called MB USA I suggested that the issue may be related to the fuel sender under the rear seat and should be covered under their recall, I was advised by them that my VIN is not part of their voluntary emissions recall campaign (# 2008-029991) even though my model year (2006), my model (E55) and my engine family (6mbxv05.5lbi) are ALL listed in their 2008 filing with the EPA for their voluntary service campaign for this vehicle.
They suggested I bring the vehicle to the dealer for diagnostics.
I did so this morning. The dealer advised that the fuel sender part number that I had in my vehicle did not match that for the recall. The issue was a leaking O ring in the fuel sender, the dealer replaced the O ring at a cost of $305 ($250 labor, the balance tax and O ring). Also the dealer very graciously said they will proactively attend to the "nipple" on the fuel sender by inserting the metal grommet free of charge next week (they did not have the part(s) in stock).
I later today called MB USA again advised them that I felt this issue should be covered under their recall notice, they have escalated my concerns to a case manager who will call me within 24 hours.
I will update as I have news.
Everyone needs to keep calling and complaining, but MOST IMPORTANTLY FILE COMPLAINTS WITH NHTSA/EPA. This is who can force Mercedes to actually fix this for us.
Funny how companies try to fix recalls with .02 cent pieces of metal and send you on your way. Just like Mercedes is doing here, and like Toyota did for sticky gas pedals. Its BS and emissions is a huge deal on a federal level. Some of you people in California need to start calling the crazies in your state. They'll have Mercedes buy us all a new E63 or something crazy the way that state works. lol
Now, it off to the gas station to fill her back up and look to see where the leak is coming from. Will report back...
If you do end up having to replace the seal. Be extremely careful removing the fuel line . It's hard to come off and you can break the plastic nipple off really easy. Go ahead and buy a new hose clamp too. Be sure and pay attention exactly how your sending unit is set in place. If you put it back in a different position ( even a 1/2 inch) It can cause your fuel gauge switch(Float) to hang on the wiring in the tank.
If so, can just that part be replaced, or does that whole fuel pump need to come out and replaced as a whole? I'm not quite sure what I'm looking at here.
I know its my fuel filter but my tech dont bother with the part and live with the Check Engine Light. I only fill mine up 3/4 full now and cleared the code.
I'll fix it when i feel like saving up $ 386
So, I'm going to go ahead and order a gasket, for both sides. And for now, try to run the car with no more than 1/2 tank.
Guys, since checking is such an easy thing to do, I suggest EVERYONE take 10 minutes and do so, if you haven't already. It takes 30 seconds to remove the seat, 10 seconds to lift up the sound deadening material, and another 45 seconds to remove the 6 or 7 screws holding the caps on, with a cordless screw gun. As you can see, there are 2 wiring harnesses down there on the driver side, so all it would take is one of those to short, and arc, and it's boom city.
May wanna just throw a new seal at it if there's one under the assembly as its easy enough to replace since you have an access port and don't have to drop the tank. Unscrew the ring, lift out the assembly, slip on the new seal and put it back together. You've been in there enough times you can do the whole job in probably a half hour being careful and for only a few dollars. Would also give you a chance to examine the molding of the tank for the imperfections people have mentioned.
Part for DS that i received was
211-470-51-94
211-771-05-79 same # for seal.
Filled up the tank all the way yesterday and no smell emanating from my garage at all this morning. Which is a good sign.
Here are the part numbers that solved my gas leak smell.
