EuroTeck Diffuser Fitment Issues
Does anyone else have this problem? Or have a good way to solve the problem? Any ideas and suggestions are greatly appreciated. I've run out of ideas and am starting to think it may be my bumper
I'm not going to blame Euroteck for the issue seeing as how they come from a mold and everyone else seems to be successful so it may just be my car... Who knows
Here's some pics to show the problem. TIA!
The trick is this...... make those mounting holes bigger then you think and, and as I was making them bigger, I made sure to taper them towards the top. Or as I kept going back to open the holes wider, I made sure to open the hole up at the top.
If you mark the bumper where the screws initially touch the bumper when you test fit it, it will not fit right. It gives you a nice starting point, but the holes have to be a little higher than it seems.
Since the outside screws go in at an angle, if you mark the bumper exactly where the tips of the screws hit the bumper, you will be way off and get a gap in center or at either end.
So after you make those marks, drill the hole much bigger then you think you need it. As you continue to drill the hole bigger, have a tendancy to round out the top side of your newly drilled hole.
I ended up with about a nickel size hole because I drilled the original holes a little low. I just made sure to use a washer on the back side.
You should notice it start to fit better, and as you open that hole up even more towards the top of the diffuser, it should start fitting better until it is perfect.
I was having this exact same situation and it was as simple as moving the holes up a little higher, although it does not look like it will fit with the holes up so high, when you flush it against the bumper it works itself out.
Thanks again for the help and suggestions guys
Also, LOAD that sucker up with double sided tape. My holes were drilled larger so the fit was good but the tape lost adhesion from the car washes, rain, etc. It started to sag so I took it off and basically BLANKETED the diffuser with double sided tape. No issues since.
. . . and then you're crying over broken carbon fiber, you can't sell it to pay for the new diffuser. . .do I need to go on?
To be honest, the epoxy does not bother me since I have no plans to ever change it.
I have a little time off tomorrow so I'll fiddle around and see what I can come up with. I'll take some pics of progress and update this thread just in case someone else has issues like this down the road.
It didn't fit perfectly until i drilled the holes more towards the BOTTOM of the bumper. It took me a few hours start to finish on the second try, including removing the old tape and absolutely covering it with new tape.
I bought a roll of the 3M heavy duty tape. They label it as the strongest stuff they have. It's thicker than the stuff that was on when i received it.
Once it fits right, it looks absolutely beautiful.
Probably my favourite mod, aside from wheels & lowering.
Can you buy the above sealers at auto parts stores?
http://cgi.ebay.com/ebaymotors/U-Pol...motiveQ5fTools
http://cgi.ebay.com/ebaymotors/DYNAT...motiveQ5fTools
