Pano Roof Broken
2004 E55, 1997 E320 "Sold"
Pano Roof Broken
Hey Guys. My pano roof had a plastic piece and spring which broke off causing the roof to not open or close. My warranty declined the fix and I was told it was $450 to fix. Has anyone had experience with repairing the pano roof? I was told the linkages and draft reflector arms need to be replaced although from what I seen it only looked like one plastic piece and a spring broke off. Any help would be appreciated on how or where I can find these parts, thanks.
04 e55 amg
mine is at the dealer right now for that.
I had a problem where it was getting jammed on one side . i dont remember if it was the wind deflector or what. But one side would get jammed. the warranty covered most of it, but they said the rails were bent or something. the dealer ended up replacing everything under warranty. the warranty just had to verify the rails were bent and apparently there was alot of labor involved taking them apart to prove this.
3k in warranty work done, then got the motor and tranny mounts replaced as well, 0 deductible .
My drivers side clip broke but I caught it before any track damage was done. I put it back together and used a zip tie. Been fine for 1yr. I need to say something before my ext warranty runs out next year.
All the parts were there in my case. I was able to snap it back together and then zip tie to hold. I could see where the parts could pop and fall out. A call to MB parts may help.
![bs](https://mbworld.org/forums/images/smilies/bs.gif)
04 e55 amg
yah my car has been there for 2 weeks for the roof. been fighting with them about it but finally got it all covered. I had the damn c class rentals. I have to say mercedes dropped the ball when they made the new c class. slow and cheap feeling imo. ready to get my amg back
I have the same problem. It got stuck on one side. They replace the motor for $800 and now they said the rails need to be replaced cause they might be bent and some tabs broke off. They said it will be another $1500. No warranty
Anyone know how to fix this yourself? I have some mechanic friends that said they would do it if could get the parts.
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
04 e55 amg
1 Post
2007 E63, 2005 Dodge Ram Hemi
Hey Guys. My pano roof had a plastic piece and spring which broke off causing the roof to not open or close. My warranty declined the fix and I was told it was $450 to fix. Has anyone had experience with repairing the pano roof? I was told the linkages and draft reflector arms need to be replaced although from what I seen it only looked like one plastic piece and a spring broke off. Any help would be appreciated on how or where I can find these parts, thanks. ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Back from the dead. I have a quick question because I think it is time to fix this damn roof! The draft reflector arm is what they told me a long time ago, but when searching for parts that is not the name it is called. Anybody know what the "draft reflector arms" are referring to? Thx
S63 AMG, E55 AMG,C Class AMG CLK55 AMG, Jeep Rubicon
Back from the dead. I have a quick question because I think it is time to fix this damn roof! The draft reflector arm is what they told me a long time ago, but when searching for parts that is not the name it is called. Anybody know what the "draft reflector arms" are referring to? Thx ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
2005 E55 AMG
I had the same issue with one side of the pano. I just unscrewed the metal finger that was left so that one whole side of the assembly is now gone. The roof now closes fine, but the glass wind shield that props up when the roof is open is only supported by one side. Works ok for now and didn't cost anything.
2004 E55
