EC has new injectors - thoughts???
http://www.eurocharged.com/index.php...mart&Itemid=66
Yes we have done a ton of research and data logging and finding around 510whp the magic number to where you start to see injectors going static at the top of 4th.
We had some made for a few customers to test and all has gone well.
Also with previous tuning customers, we will rescale the tune for free for you to take advantage of the extra fuel!
With the new tune, idle was perfectly fine and they are making great power. Exotic-metal is currently running them in his car and should make for some great numbers in the texas mile coming up in october!
Can't wait to see how these perform!
Is this also a direct drop in or would any modifications be needed?
1) Remove air boxes and engine cover.
2) Remove throttle body.
3) Loosen hose clamps on AMG air tanks located on rear of engine near firewall.
4) Remove Air tanks and leave bolts in air tanks, as they are different lenghts.
5) un-bolt main fuel line to fuel rail (17mm wrench and located on drivers side). un-clip wires from injectors.Then lightly pull up and rock injectors out of head manifold inlets.
6) Put tape over head manifold inlets, to protect from dirt and any dropped parts..
7) Use needle nose pliers to pull off injector clips and twist out old injectors. Drain gas out first and dispose of per EPA standards or re-use..
8) Now STOP and admire your new super red injectors and note how much larger the spray holes are. Also notice the nozzle spray cup on the end.
9) use light motor oil and lube up o rings on new injectors and twist into fuel rail.
NOTE: These injectors flow over 700CC at 65PSI and up! They install and car will run and idle fine.. You will need Jerry to flash a new tune that he has built, so that everything will be calibrated and A/F set for max power..
Can this same manufacturer work with you on possibly finding a 550cc injector? I don't plan on modding anymore and something more in that line would be great.
BTW....I sent you an email
im probably speaking out of my *** but id guess that the EC injectors are a %50 gain over stock
yup you r right. i remmeber it was in the low 400 range. but they are sure not 700cc.
but if my car is not lean, i don't think they are needed in this stage, i may go for them if a install larger TB, CAMS, C/F intake box. if the car still needed some fuel.
however, it is a great product and the first for our cars. EC guys are doing great
