All of this throttle body shaft grind talk is .............
Old Jun 22, 2011 | 07:12 AM
slownrusty's Avatar
'06 E55 K2
Very nice work...got me thinking about a 74mm TB!
Old Jun 22, 2011 | 01:01 PM
tbal's Avatar
Haters crazy
Originally Posted by stevebez
Nice job pearlpower....
Ok I get the fact that the cross sectional TB area is larger now allowing more flow but I dont see how it can bring about anything close to 20hp gains....esp when applied to the larger TB's....
I dont see 20hp either, maybe 5-6hp? For free, its not bad! lol
AMG RL thanks bro, I will probably give it ago sometime before I dyno (if nessessary get re-tuned)
Old Jun 22, 2011 | 01:14 PM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Guys the 20hp gains claim has been discussed in depth with track times on other threads ,please do not rehash the same old arguments here. It could be a thousand hp, means nothing if you cannot drive or put it to the ground. This explains why those here with the most HP are rarely the quickest.
Old Jun 22, 2011 | 01:48 PM
tbal's Avatar
Haters crazy
I'm sure you can put 20hp to the ground :P
All jokes aside, whether its 1hp or 20, point is its free, and it helps so don't see what the argument is, just do it!
Old Jun 22, 2011 | 06:42 PM
jcjmw's Avatar
2005 E55 Wagon
I grinded the shaft in my VRUS 80mm TB. All I can say is that I felt increased power right after the grind. That "increased power" could be felt for about 3 days of driving. Then, I guess I got acclimated to the increased power. However, there is no doubt you will feel the increased power. I believe ALL that hv done this mod will say the same.
Old Oct 5, 2011 | 08:47 PM
betrezra's Avatar
C63 507 AMG DA Car #19
To truley test this either:
A) dyno before/after (same day, same dyno) OR
B) track the car before/after (same day, same weather, same level of heat soak in engine)
I just don't see 20hp in this..... but I'm being honest.
It is VERY hard to feel 20 hp on top of 580!...... do A) or B) above and I'm a believer.
No flames...... just my opinion... we all got em
Old Oct 5, 2011 | 09:19 PM
  #32
cal1's Avatar
SL55, ML500 & Acura TL
Just thinking out loud here, but where are the extra ponies coming from? More air? If so, more air means a leaner condition. Maybe not enough more air to create dangerous AFRs, but maybe so depending upon other mods and tune.
Old Oct 5, 2011 | 09:25 PM
  #33
AMG_RL's Avatar
E55 AMG, 72' Toyota Carina, 63' Ford F100, 72' Mercedes 250c, 15' Harley Davidson Softail
the ecu compensates fuel for increased volume of air.
Old Oct 5, 2011 | 09:33 PM
  #34
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
I think AWOL's post earlier in the thread proves it... Going from 118 to 120 mph trap in the 1/4 mile..
Old Oct 5, 2011 | 10:50 PM
  #35
cal1's Avatar
Is this true under all conditions? The reason I ask is I had a RT pulley and tune done. The AFRs were where they should be. I then added an 80 mm TB and shorty headers. Thinking the ECU would compensate, I did not retune immediately. When I did, I learned my AFRs were on the lean side.
Old Oct 5, 2011 | 11:04 PM
  #36
pearlpower's Avatar
ECU on any car will adjust but only to a certain degree. Your mods are above minor so one could not expect the ECU to compensate which is the reason for a tune to begin with.
Old May 13, 2012 | 08:30 PM
  #37
Celicasaur's Avatar
W212 - E63 AMG
I'll jump on the bandwagon too with this and chime in with my opinion...
I did this mod myself over the weekend pretty much exactly as the pics show in the first post of this thread.
The car feels slightly more crisp on half throttle, like it is happy to give me more power at slightly less throttle input (not sure if that makes sense to anybody) but most noticeable is the full throttle surge up top. It's not a huge difference, but it's definitely noticeable and the car is slightly more willing to pull as it tears towards redline.
However, if I bought an 82mm throttle body for the insane amount that they retail for, i'd have been very disappointed in terms of power/cost, but this is apparently fairly close to it and it cost me nothing so I'm happy and enjoying the better driveability now
Old May 13, 2012 | 09:21 PM
  #38
mrweelr's Avatar
2016 CLS63S AMG, 2017 GMC Sierra Denali Ultimate, 2019 KTM 1290 Super Adventure R
Are there any pics showing how to remove the throttle body and do new gaskets need to be purchased for reassembly? Any risk of getting metal particles in the throttle body passages? Just want to be clear before I tear into mine, thanks.
Old May 13, 2012 | 11:19 PM
  #39
pearlpower's Avatar
Easy to do; the issue I receive more PMs on is a code afterwards caused by not completely inserting the hose below the throttle body into the throttle body. It is also held on with a clamp that attaches to the two lower throttle body bolts. It holds the hose up into place so that it does not fall out.
Some have also had to perform a throttle body 'reset'.
Old May 13, 2012 | 11:43 PM
  #40
mrweelr's Avatar
Cool, thanks. So no new seals or gaskets needed then?
Old May 13, 2012 | 11:59 PM
  #41
pearlpower's Avatar
Nope, just reuse the stock metal ones, good cleaning is all.
Old Dec 19, 2012 | 03:32 AM
  #42
swedepat's Avatar
2011 C63 AMG, 589hp
Nice thread. did this on my c55 the other day, no chance to drive it due to snow.
but i did som calculations for fun.
you almost gain area equal to an 78mm throttlebody if you grind the shaft down to 5mm wide, originally it´s 10mm.
And to put sugar on top,, adding an 80mm throttle on an std C55 or early e55(N/A) will not gain as much as it could due to the area in elbow is to small likewise the airmeter.
Rgds
Patrick
Old Dec 19, 2012 | 12:32 PM
  #43
Toadster's Avatar
2005 E55 AMG
comparison pics of before/after?
Old Dec 19, 2012 | 04:10 PM
  #44
blackbenzz's Avatar
haters crazy
Did you look at the first post? And before is obvious
Old Dec 19, 2012 | 04:29 PM
  #45
Blown_V8s's Avatar
C5 LS6 and CLS55
WTF, grinding the shaft down? I'm confused. Do you all mean "Porting" the TB?
Are you porting around the blade or grinding the bar in the middle of the TB?
Old Dec 20, 2012 | 04:36 AM
  #46
blackbenzz's Avatar
haters crazy
AThey are grinding the bar
Old Dec 20, 2012 | 09:40 AM
  #47
Blown_V8s's Avatar
C5 LS6 and CLS55
thanks
Old Dec 20, 2012 | 08:11 PM
  #48
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Nice job and great pics! Use locktight on the screws for saftey, in case you did not use any.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Dec 20, 2012 | 11:24 PM
  #49
berti_00's Avatar
2016 Cls63s AMG
What you guys think of this
http://www.ebay.com/itm/Mercedes-E55...ce2ec7&vxp=mtr
Old Dec 21, 2012 | 08:17 AM
  #50
vettdvr's Avatar
03 E500 and Corvette
Ok I don't have a AMG and I stayed at Holiday Inn but I do drive E500. Will this mod work on E500? I'm always up for more hp.
