need e 63 conversion help
211-885-08-16 Reinforcement For Lower Bumper $22.10 (This part bonds with double sided tape to the outside of center bumper opening)
i have the 2 pieces you mentioned the body shop did not know where they went
There are also 2 more pieces im missing they go on the low back corners of the cover they attach to the 3 tabs on each side of the cover inside and attach to the outer renforcement right now the outer renforcement is floating in the breeze any help or photos of the inside of a e63 bumper would help
another thing i found was 2 brackets T shaped, not sure where these go?
I bought the bumper used a while back from Germany so i cant even ask the seller!
yes
A2118850111
A2118850211
apparently these are license plate cover fastnings.... something you dont have to worry about in the US.
definately not the support you were asking about! after looking at my bumper it doesnt have any such support either!
Im going to go ahead and install it anyway tommorrow and order the supports afterwards if it looks like it needs it!
also found the 2 clips taken off at the bottom corner of the wheel arch have nothing to attach to before they attached to the belly pan.
