VRP pulley swapable?
Old Sep 23, 2010 | 09:40 AM
skratch77's Avatar
2005 E55
I have a 175 sitting here and you can take the pulley apart and swap it for another size.
Can we buy the different sizes from them?Im loking for a 172 to slap on the other half of the pulley.
Old Sep 23, 2010 | 10:30 AM
TTMotorsports's Avatar
Former Vendor of MBWorld
Whatever we're tuning!
So you have the pulley design where the outer pulley is bolted on?
That bolt on design has been proven to be a failure. The amount of heat and torsion placed on the outer pulley is tremendous. Usually the bolts fail and then you have some major problems.
Do a search about pulley failures Angelo.
Old Sep 23, 2010 | 11:35 AM
skratch77's Avatar
2005 E55
This is bull ****,every pulley out there other than renntech and kleeman are all junk. Do you think i can put something in the threads to keep them from coming loose? Or even weld the damn bolts on there
Old Sep 23, 2010 | 12:47 PM
Welding would be much better and stronger than using bolts! The major issue with that is you are going to have to balance the pulley after welding the outer ring on.
Old Sep 23, 2010 | 12:57 PM
shardul's Avatar
2003 W211 E55, 2003 W220 S600
all f*@#ing VRP pulleys wobble. I have had 3 different VRP versions on my car all did the same.
Old Sep 23, 2010 | 01:17 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
I'm not so sure about that there are a bunch of guys running the ASP 180 and haven't had any issue's. Evosport was suppose to be coming out with a 175 or a 178 but I haven't heard anything lately.
Old Sep 23, 2010 | 01:36 PM
skratch77's Avatar
2005 E55
My asp 180 wobbled and had no damper on it.
Old Sep 23, 2010 | 01:55 PM
shardul's Avatar
To OP
The answer for your question is yes if you can find someone to machine a bigger outer ring for the pulley you can mate (bolt or weld whatever your prefer) it to the inner pulley. The whole unit will have to be balanced again.
Seems like VRP is dormant or out of business they were in the process of making different size outer rings. Maybe you can contact Victor and see if he still has some one hand.
Old Sep 23, 2010 | 02:35 PM
Simon @ evosport's Avatar
PREMIER SPONSOR
I know you're frustrated, but your comment is FAR from the truth. I can only speak about our pulley, but it's hands down the best built pulley on the market in my opinion. We've never had the issues you are having with yours.
Our evo1+ Power Package with 178mm pulley has been out for several months now.
