side mirror problems, please help!
Old Sep 27, 2010 | 08:00 PM
AMG_RL's Avatar
E55 AMG, 72' Toyota Carina, 63' Ford F100, 72' Mercedes 250c, 15' Harley Davidson Softail
so I looked around the forum and couldn't find an answer. my side mirror adjustments stopped working about a week ago. it's weird because when you change the memory settings the mirrors move, but when you try to adjust the mirrors using the buttons, it doesn't do anything. anyone know what could be the cause of this and possibly how to fix it?
Old Sep 27, 2010 | 09:00 PM
azncantonw211's Avatar
2005 E55 & 2007 335iC
ditto!
Old Sep 28, 2010 | 10:34 AM
AMG_RL's Avatar
bump for an answer!
Old Sep 28, 2010 | 11:24 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
i would connect it to STAR and check the driver side SAM for any fault codes.
Old Sep 28, 2010 | 11:30 AM
mekantor's Avatar
2003 E55 AMG; 2013 GL550 4Matic; 2003 CL600
Sounds like the mirror switch is bad or unpluged. The memory settings are in the control unit of the door, and that is what actually moves the mirrors. The switch plugs into the control unit.
Lucky for you, I have a spare switch that I can sell for cheap, if that is indeed the issue. Its pretty easy to pop off the door panel if you have some torx bits and a plastic wedge to pry out a few panels.
Old Sep 28, 2010 | 11:31 AM
mekantor's Avatar
or move around the mirrors with STAR
Old Sep 28, 2010 | 12:32 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Sounds like the mirror control relay, has malfunctioned. It will most likely need replacing.
Old Dec 22, 2010 | 03:59 AM
Zmydust's Avatar
996 Guards red / 2008 Hayabusa / 2004 E55 AMG
Same issue here
Old Dec 22, 2010 | 11:26 AM
mekantor's Avatar
I still have a spare mirror switch available
Old Dec 22, 2010 | 05:39 PM
Zmydust's Avatar
pm'd you
