Help Identifying Phone Connector Type (E55 MY2004) Japan
I'm new to both the forum and this is my first Mercedes - the experience to date has been excellant. Just a few minor things I'd like to get going if at all possible so I'm hoping someone out there may have some info.
I have a MY 2004 E55 that is a Japan Spec car - it has been imported to New Zealand and I'm trying to find a way to get either mobile handset or a bluetooth module to work in the car - with the existing cradle cord if possible.
After spending hours searching and checking images and trying to locate what kind of mobile phone, or connector plug this is, I'm running out of places to check. I have even been into my local dealer and they have checked with Mercedes NZ and have no extra info to help me, other than they don't think a bluetooth module will work - the standard plug for it doesn't fit this - so I'm hoping someone out there may be able to identify from the images attached what it is - or what kind (part number) of cradle types it may plug into, as the cradle that is with it is a Mercedes Universal cradle (part # A 211 820 04 51) that holds the plug and the phone goes into the plug directly.
I'm advised it is a similar scenario for the GPS - no option to update the maps etc to Aus/NZ - thats not a huge deal as a separate Navman/Garmin etc is fine - to change out the Command unit is estimated at $7000-10,000 NZD.
I would greatly appreciate anyone who can provide any idea as to what this plug might fit - Mobile Model/Type etc
Tks - Craig.
Thanks for your quick response - I have tried to get a clear pic of a Siemens S75 to compare but there are not many about that conclusively show the same number of connectors pins etc - it does look to be the closest option though. On closer inspection it appears a little different - if anyone out there has seen this connector (with something actually plugged into it) I'd love to hear what it was.
Will keep searching.
There is a dynavin headunit option depending on whether you have an Audio20/50 APS etc also if you want to search or google it for more info.
ETA: There was recently a thread on someone doing a swap out for a Kenwood unit, if you search.
