Some pulls against an e60 m5 *video*
Old Nov 24, 2010 | 08:43 AM
slownrusty's Avatar
'06 E55 K2
Great Videos! Nice to see the E55 hanging tough after 7+ years!
Old Nov 24, 2010 | 08:56 AM
WayneE's Avatar
'72 Suburban
Originally Posted by M-bENZ
this is it.
Test Data M5 E55
1/4 mile, sec @ mph 12.6 @ 115 (est) 12.4 @ 116.2
At one of our drag gatherings at Capital Raceway, there was an 06 M5 SMG and my 06 E55. Both stock with around 6k miles on them. The owner of the M5 gave me the keys to his car and I made a bunch of passes.
I think ran the quickest time in his car, which was a 12.57@117.9 on a 2.1 short (this was several years ago, so I might be off a hundredth somewhere ) and my car ran a 12.16@115 on a 1.85 short.
Same day, same driver, same track.
The M5 could not get out of the hole quick enough with the neutered US LC on a prepped track.
I'll see if I can dig up the old posts on it.
Old Nov 24, 2010 | 09:03 AM
WayneE's Avatar
'72 Suburban
https://mbworld.org/forums/w211-amg/...ighlight=12.57
Old Nov 24, 2010 | 09:47 AM
lowprofile's Avatar
E55
Originally Posted by vw_mkv
.....I did a pull with a friend last week and my M5 pulled away from a 30mph roll. We only managed to get one run in because his car was heat soaked after the first run even in this cold weather.
Do your friend a favor and tell him to check his I/C pump. Your description screams "bad pump". There is no way any healthy 55K should be heat soaked after one pull in cool weather.
Not surprised by your results at all Awol.
Old Nov 24, 2010 | 11:43 AM
rat3d m's Avatar
M3
was that m5 owner shifting at proper RPM also was the M5 settings adjusted to P500 ? more details please ....
Old Nov 24, 2010 | 12:33 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Starting to think this dremel'd throttle body is the GREATEST FRIGGIN MOD OF ALL TIME!!!
Gotta understand, for years the M guys have been torturing us with the same vids.....the M slowly pulling away at higher speed.
http://www.youtube.com/watch?v=8aVZ9...eature=channel
Even the friggin wagon...same result.
Could the TB mod and snorkel give the E THAT much power? Pretty cool vid
Old Nov 24, 2010 | 01:24 PM
  #32
Marky's Avatar
AMG
My former stock S65 vs stock M5: http://www.youtube.com/watch?v=a7hiI...&feature=email
The same S65 vs stock E55: http://www.youtube.com/watch?v=hIoj1...e=channel_page
Old Nov 24, 2010 | 04:31 PM
  #33
AWOL's Avatar
e55
To chime in here, dont count any of those gtboard or m5board videos for much of anything.
Look at the real world track times. You wont see a stock m5 run an 11 second 1/4 very often, and there are plenty of members here that have in the stock e55s.
All I can really comment on is my car. It has proven track times with the most basic of mods. Pretty solid runner considering it now has 98k miles on it.
We ran to 155mph on the last pull and I had the camera guy and I was always pulling.
And that stupid tb grind is the best mod for sure. So simple, so noticeable of a result. The day it was done, I noticed a stronger top end for sure, traps went up 2 mph as well.
And yes, the m5 was in full 500hp "mode" or whatever
Old Nov 24, 2010 | 04:42 PM
  #34
cahiil55k's Avatar
[TwistiesSuit]
Amen to that! A bunch of M5 and M6s are running 13's or near it.
Your car is very beastly considering it is mostly stock and untuned. You held your own and then some, up to the limiter.
That doesn't help if the guy isn't a NASA engineer or F-16 fighter pilot.
[/TwistiesSuit]
Last edited by cahiil55k; Nov 24, 2010 at 04:46 PM. Reason: forgot to put on my twisties suit
Old Nov 24, 2010 | 05:45 PM
  #35
SMP's Avatar
SMP
CLK63 Black Series
Originally Posted by Das Geld
LOL just reading those comments from Youtube by TZRINI makes my blood boil.
The only reason people always say "OH BMW M5 Pulls up top blah blah" Its the Gearing Blah Blah..NO..It's the Heat-Soak E55 Blah Blah.. NO
It's that it has 40 more HP than an E55 that's why it starts catching up as the E55 has the Torque to get it there sooner. Once they both have 507 hp ,bye bye M
It's actually a combination of factors, not just the gearing. I'm talking strictly about an M5/M6 with SMG, as the V10 was specifically designed around that transmission, not the 6 speed manual. The M6 has a slight weight advantage of 100 pounds over the M5.
The SMG is a 7 speed automated manual gearbox with less parasitic loss compared to an automatic transmission with a torque converter, which makes a big difference at triple digit speeds. In the SMG's most aggressive setting, the shifts are much quicker than in the Mercedes. Combined with an 8200 rpm red line and the V10 from 6000 rpm in it's optimum power band, makes these cars pull hard on top.
From a FWY speed roll, providing the M is in the right transmission settings, both cars are about even up to 130. After that the M starts walking. From a dig or slow roll, it's the Mercedes all the way, as it would take the M quite some time to catch up.
Both are great cars. They were just built with different philosophies in mind.
Old Nov 25, 2010 | 03:06 AM
  #36
tbal's Avatar
Haters crazy
Well said...
Also to mention, that S85 V10 is absolutly gas hungry, you make friends quick with your local gas station... haha
Old Nov 25, 2010 | 03:18 AM
  #37
Das Geld 2's Avatar
SL55, S500
Good Post, but the OP's video proved that doesn't matter LOL
Old Nov 25, 2010 | 03:25 AM
  #38
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Some of you folks just flat out over analyze the simplest things. When I smoke an M5, I do not ask if they car was in 500 mode, and care less about this gearing, power under the band, blah blah blah. I smoked him, settle at that until the next M5/6 comes my way.
Old Nov 25, 2010 | 03:38 AM
  #39
SMP's Avatar
SMP
CLK63 Black Series
Originally Posted by tbal
Well said...
But not only for gas, oil as well. I always have a qt. of Castrol in the trunk. My CLK is about as thirsty though.
Old Nov 25, 2010 | 12:58 PM
  #40
Vic55's Avatar
Administrator
Well if there was no over analyzation- this thread would be on page 3...
With your mods I dont see any reason to assume that you would not smoke a stock M5, let alone a 6 speed. To me its apples and oranges. A stock M car with the weaker 6 speed versus a car with probably 80 more whp. No brainer.
Everyone knows the E55 is underated in hp stock and the S85 engine in the M reads about true to spec per many many stock dynos. So add in your mods and you walk away as demonstrated.
Nice win.
Old Nov 25, 2010 | 10:57 PM
  #41
AWOL's Avatar
e55
I didnt post this to cause a ruckus, or create deeper beef against the bmw crowd.
I posted a challenge on a local forum. He accepted. We ran. My car is faster.
Find me an m6, and Ill race that too. The other local SMG m5 wont race me
this was all in good fun gents
Old Nov 26, 2010 | 12:37 AM
  #42
pearlpower's Avatar
Nice win.
My point is more.......people internet race too often and even after all of the stats, dynos, magazine quotes,etc.. in the end, the driver still has to properly launch the car and that there is where many drop the ball. We have all raced and beat a faster car I'm sure.
Just so much more than simple stats even if just stock to stock. A win is still a win, 400 mode or not, many seem to forget that the person that is ahead wins.
Old Nov 26, 2010 | 04:45 AM
  #43
OXOJE55's Avatar
///AMG
Nice kill vid
Old Nov 26, 2010 | 04:50 AM
  #44
skratch77's Avatar
2005 E55
Im pretty sure you told me you were running an agressive eurocharged tune awol.is the car on stock tune and trapping 121 because your trapping the same speed as me with all my mods, you sure you don't have a pulley on there too lol.
