Question for the pros. DAS question. What is Off Line Coding? Any ideas
Old Dec 8, 2010 | 01:19 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
John Coupland over at JC Recordings just announced a new crack for the Star Das that will allow you access to a bunch of restricted areas (can't post them all as he is not a sponsor) but a few are
Instrument Cluster (In DAS) r
Off Line Coding
204 Access In DAS
Electronic Transmission Control
Adaptive Braking System (ABR) Special Fuction 1
Adaptive Braking System (ABR) Special Fuction 2
Electronic Stability Program (ESP)
Air Conditioning
Instrument Cluster (In Xentry)
Any idea what Off Line Coding is? Could this actually be a way into the ECU for programming of certain areas. Just curious what you guys thought.
More info at JCRecordings.com
Old Dec 8, 2010 | 02:11 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Will look into this tonight and report back! I also just got the email.
Old Dec 8, 2010 | 04:16 PM
AMGPilot's Avatar
2004 E55
Offline means that the star doesn't have to "Phone home" to do the coding
Old Dec 8, 2010 | 05:39 PM
aleksandar1099's Avatar
Top Answer: 1
Mercedes
+1
It means it does not have to connect with Xentry online to perform the coding...
Old Dec 8, 2010 | 06:31 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
What are you up to now Jim?
Old Oct 18, 2014 | 10:12 AM
Sully114's Avatar
W211
Hi, I need this option where can I get it please?
Old Oct 18, 2014 | 10:46 AM
jerryt's Avatar
SLK250
My understanding is that 07/2012 version of Xentry has offline coding enabled.
2012 not 2014
Old Oct 18, 2014 | 10:50 AM
Sully114's Avatar
W211
Thanks for getting back to me, so its only available in this version and not possible in other versions? I have read about patches/addons that enable this feature, although they do not mention which versions it works on.
Old Oct 18, 2014 | 10:54 AM
jerryt's Avatar
SLK250
Thanks for getting back to me, so its only available in this version and not possible in other versions? I have read about keygens that enable this feature, although they do not mention which versions it works on.
See my response in other thread
https://mbworld.org/forums/mercedes-...ml#post6201990
Old Oct 18, 2014 | 10:14 PM
Chomanche's Avatar
2007 E63 Amg, Heavily modified 1988 Jeep Comanche
The computers all have a base program and an add on that tells them how to run. The thing about it is the level das you have has that level base program. The reason it has to log into Daimler is for the add on. They're really just build codes distributed into whatever needs that build code to opperate its part of the tasks.
