Check engine light is on
Old Dec 21, 2010 | 12:16 AM
black05scamg's Avatar
2005 e55 black on black 07 e63 po30
My check engine light is on I checked it and got a code of
P0128
Old Dec 21, 2010 | 12:25 AM
wally AMG's Avatar
MB
Coolant Thermostat code....
Old Dec 21, 2010 | 12:35 AM
Is it hard to change in this car
Old Dec 21, 2010 | 06:49 AM
brunoboxer's Avatar
04 E55 470 whp
Isn't it the sensor and not the thermostat?
Old Dec 21, 2010 | 09:53 AM
spazmoid's Avatar
2018 E63s, 2004 E55 AMG
I just got this code too. I haven't done anything yet though, except clear it and hope it doesn't come back. The definition i got was either faulty thermostat or coolant temp sensor. Anyone know which one it usually is on these cars?
Old Dec 21, 2010 | 09:55 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Very easy to change Tstat if that is what the problem is.
Old Dec 21, 2010 | 07:35 PM
well i replaced it today not bad just need to take off the supercharger
blet its under the charger i cleard the light hope it dont come back
i also looked under my car and i have trans fluld leaking but i think its a hose thats like $16 bucks at the stealer btw i paid $67 bucks for a new thomo
Old Dec 22, 2010 | 02:09 AM
mikey33's Avatar
2004 E55, 1997 E320 "Sold"
I got the same code and low coolant message and checked and my coolant was low! It happened right after I put my meziere pump on and split the cooling, so I must have left an air pocket in the line because there were no leaks. I filled it up and the coolant message went away, but was then driving around with a check engine light for like 3 months. All of a sudden a few days ago I noticed that the check engine light was no longer on, and it must have got erased when I changed my steering wheel out and had to disconnect the battery because all my settings in the car also got erased. Needless to say I am very happy
Old Dec 22, 2010 | 12:10 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
You had to take off the supercharger????
***edit...just noticed the blet.....nevermind. *** LOL
Old Dec 22, 2010 | 07:47 PM
alextaylor29's Avatar
2004 E55 AMG
Quick question how do you do the "Check Engine Light" code check in the menu? Or do you need a special tool for this?
Mine just came on as well but I figured it was related to me needing to get the E+ service done which I'm pushing to January as I had the car completely serviced a few months back.
Thanks!
Alex
Old Dec 22, 2010 | 08:53 PM
mikey33's Avatar
You need to use an obd II scanner
Old Dec 22, 2010 | 10:14 PM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Wait....
you mean it's not supposed to be on?
With all the combinations of errors on this late model stuff, it's really interesting only if they are NOT on.....
Old Dec 23, 2010 | 12:33 PM
2004 E55 AMG
Where could I buy a obd II scanner?
Thanks.
Alex
Old Dec 23, 2010 | 12:51 PM
TopGun32's Avatar
cold weather could set off the code... your coolant temp is probably under 80c
Since I have a modified Tstat.. the coolant was not reaching the correct temp and ECU gave the CEL.
I cleared it with my OBD2.
Nothing to worry about unless the coolant temp is getting higher than normal.
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
